nissan 180sx
sr20det redtop
the car has rego until mid november
the bonnet shown in the photos is a spare bonnet i was planning to fix and put on the car
it is a topsage replica made from metal and the topsage vent made of fiberglass and grafted into the bonnet
front mount intercooler
new adjustable turbo smart boost controll
currently the boost is set at 12psi which is a comforable level
drift blow off valve multi fit
new gauges
-boost gauge
-water temp gauge
-volts
-turbo timer
4 new tyres
new battery
the interior is very clean never smoked in while i have owned this car and kept clean
car is washed weekly
the body kit is made of a c-west front bar
veilside side skirts and veilside rear pods
the body kit is a perfect fit no ugly gaps
and no cracks or broken bits anywhere
car is resprayed midnight blue
it had a new windscreen put on 3 months ago because of a stone chip
air conditioner and heater work great
recently put in a new cd player
motor serviced 1000kms ago new plugs oil change ect
always looked after
this car passed a roadworthy 2 months ago and i havent done much to the car since
so i dont see any reason why it would have trouble passing a roadworthy again
any questions
i will Sw@p for something else of interest tell me what you have to offer vt or vx or ute ?
$7000 ono
if you are after photos text me and ill send you some i wasnt able to upload any
call or text 0400756748 any time
Edited by lukesii
https://www.sau.com.au/forums/topic/369730-nissan-180sx-turbo/
  • 4 weeks later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
