I changed the oil in my S14 6 weeks ago I check it every second day
The level never changed till the other week when I got it dyno tuned
Ive now lost 500ml in 2 weeks my mechanic says the engine is healthy and I'm not leaking or getting any blue smoke off the the exhaust or any smoke out of the oil filler cap and I don't have a catch can
Where's my oil going?
https://www.sau.com.au/forums/topic/369763-losing-oil/
Rear seals? Cam seals? Crack seal? Oil filter not tight enough? If it's not burning it most likely is dripping. Leave some news papers under you car and look for drip marks. He can't say you're not leaking when you clearly are...
Edited by SargeRX8
https://www.sau.com.au/forums/topic/369763-losing-oil/#findComment-5893969
No I'm saying I'm no leaking I have checked all over the car no leaks
Where I park it at work the concrete is very clean I park in the same spot everyday and no leaks or dots of oil on the ground,
I do get a bit of white smoke on cold start up but that's just condensation right?
https://www.sau.com.au/forums/topic/369763-losing-oil/#findComment-5894181
White smoke is condensation in early mornings. Black smoke is normal too on startup just indicates the car is running rich to warm get things flowing. If you blow white smoke while driving its water. If you blow blue smoke its burning oil. If you are certain you are losing oil, it must be going somewhere. I don't know if the oil would retain it self but if you leak oil from the rear main seal, it might be pooling up in the bellhousing of your gearbox but this is very unlikely as the oil will definately seem through the seam where the housing meets the engine. This is a tough one. If you aren't burning it, you aren't dripping it, I'm stumped. Unless its leaking out of your head gasket, onto your exhaust and burning up before you have a chance to see it. This happened in our van, oil was leaking straight onto one of the headers(dangerous shit) and burning up. We had to keep topping it up then somehow the mechanic said its leaking oil onto the exhaust and burning up... Then again we had drip marks on the ground..
Have you recently added anything to the oil system like a cooler or relocation kit? Is it still losing oil after you top it up or has it stopped?
https://www.sau.com.au/forums/topic/369763-losing-oil/#findComment-5894284
I just topped it up I'll see if it loses anymore
No nothing added to the oil system
Turbo is working fine so I don't think the turbo is leaking from a seal, it definatley doesnt smoke after warm up
It's got me stumped too
https://www.sau.com.au/forums/topic/369763-losing-oil/#findComment-5894294
Ok now don't laugh at me... I did burn alittle oil during the dyno tune I'm guessing because there car was rum very hard
But when I thought I lost more it was because... I can't believe I am admitting this... I was checking the oil while the car was on a slant.... I checked it today at work while it was perfectly level and the oil was perfect a little high acctually. Whoops my bad thanks anyway guys
https://www.sau.com.au/forums/topic/369763-losing-oil/#findComment-5897136
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
