hahaha NO f**k that shit. What you can see a hint of on my ribs there is the name, date of birth, and date of death (if they've passed) for each of my 5 family dogs I've had through my life. Decorating the 5 lines of text is a bit of a generic/cliche rose bush/vine design that extends from the bottom line of text on my side, over my back, all the way up to my right shoulder. On my right shoulderblade I have another 2 lines of text, which are lines from a song.
Keep your shirt on for the next 6 months.
problem solved.
General idea lol. I'm gonna reduce calories by a little bit shortly since I really am over eating, but otherwise f**k it lol
Good progress dude.
What mutt have you got at the moment? Got a post up in the wasteland thread?
I've had 2 blue healers and 1 red healer (all passed), and currently we have another 2 blue healers. I haven't posted up any pics in that thread as I don't have any decent ones right now :( will have to harass my mum for some haha
  • 3 weeks later...
Shameless bump with some updates.
Lift progressions:
Bench press - 100kg 4 sets of 5 reps
Weighted dips - +50kg 4 sets of 8/7/6/5 reps
Incline DB press - 36kg 5 sets of 9/8/7/7/5 reps
Incline leg press - 380kg 1 set of 6 reps
I've started to get over the seefood bulk diet, there's not enough structure in the macros allowing for a little bit more fat gain than I'd really like...that, and I'm actually starting to bore myself of food hahaha. As a result, I've decided to cut back for a few weeks to regain some definition, then get back onto a MEASURED calorie surplus for a more steady gain for a while. Top pic is obviously one from before, second pic is one from this arvo after my first day of a harsh carb cut (compared to recent intake at least) as a reference for a starting point of this cut period. Top pic makes me look much more muscular and vascular thanks to the ludicrous amounts of carbs I was taking in haha...plus it was taken while getting changed in the gym (after back+bicep session).
Progress pic time....hate how taking a photo from waist height makes chest+shoulders look narrower than they really are :( oh well lol
hahaha cheers :D I can't wait til I can have my very first pic from the first post in this thread alongside my "final result" pic I'll be taking at the beginning of summer. Gonna blow my mind in the best way possible!
Even now I don't recognise myself rofl
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
    • That's not completely truthful now is it? Any flex fuelled factory cars also had the option to run on steam.
    • Yeah so I guess your mechanic would know turnaround better than me....but I would have thought you had access to same day or overnight rack rebuilds there....any big city here in Australia has that service.   There are a couple of o-rings and seals involved, I guess the risk is the part is specific not general. Other option is if you can have it on stands in your garage for a while, steering rack removal is pretty simple (2 mounting brackets, 2 ball joints (separate by undoing the nut to the top of the threads, put a pry bar between the steering arm and control arm to put pressure on it then medium force on the side of the ball joint or top of the nut with a hammer to break it free) and then the trickiest bit is the splines to the steering rack (not too bad to undo, one nut then it slides out, but mark it first so you can reassemble it straight)
