Never had shoulder issues until doing MP, I avoid it, given the amount of people who comment similarly, I wonder if the body really likes that movement at all.
I did the movement for 9 years without issue; was probably the first exercise I ever did at the gym. Very important to start light though and don't go hero on it just because you can lift more - it probably needs flawless technique more than most exercises and your supporting muscles need time to build up too.
Start light...with an empty bar or broomstick if you have to. It's important that you have the flexibility and mobility to pull the movement off before you even consider putting a working weight on there. It doesn't take that long to get used to it; from my teaching of it, usually about 3-4 sessions before someone has a decent balance while pressing the bar overhead and maybe 8-9 before they develop the mobility to touch the bar on their neck (based on someone with poor mobility to begin with).
My 2c.
The seated version has advantages in terms of control/ isolation. Good if you are keen to work the shoulders for growth development and don't want to think too hard. Not so hard.
However, Standing press adds extra in terms of developing balance, core and suporting strength and requiring it.
People have no business really doing it without the following;
* proper thorasic spine extension . Can you extend properly? (wall slide tests on youtube)
* Scapular stablillity? (shoulder flexion test check it )
* Do you know how to brace your core
People don't learn to brace their core. This is an explanation might not be a good one.
Take a big breath of air into your belly and lock it there.
Your rib cage needs to be locked by contracting your abs.
Tighten/contract glutes
Raise up shoulders/ elbows to create a lat shelf , contract lats.
If you were taught by someone without covering these basics , then you were taught wrong. Thats before I'd explain the press.
Behind the neck press standing, is a characteristic of not having much clue with what I have seen in the past at gyms. Let alone picking the weight up off the dirt to do the movement. I won't say 'cleaning' the weight as it never looks anything like it.
This sounds like me, I do it and have sheit mobility slowly increasing my weight up and started off by not pushing myself too hard
I usually do a few sets of seated dumbbell shoulder press then move onto the standing barbell
Edited by UNR33L
  • 1 month later...
I'll have you know, I'm the owner of a fully fledged $120 Dunlop Mountain Bike I got from Big W... which I rode for maybe a month before my insistence on trying to ride everywhere in top gear saw me bend the sprocket on the rear gear set =\ Quality craftsmanship right there...
Also, I lost a bet in spectacular fashion when I failed to achieve 100km/h on the exercise bike digital speedo. The caliper/resistence system exploded and I launched off the bike around the 95km/h mark (I doubt it was accurate but it's a good story).
So I've got plenty of manly man bike experience.
Next you'll tell me you wear lycra shorts...
EDIT: Nice Dualie
Edited by ActionDan
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
