CHEEP CLEAN TURBO R33 -- SOO MANY GOODIES :)
CAR IS HARDLY DRIVEN NOW, ALWAYS GARRAGED
96 R33 SKYLINE SERIES 2 GTST
LOCATED IN NEWCASTLE NSW
BODY
FACTORY SILVER PAINT IN EXCELLENT CONDITION
LEGAL 35% DARK TINT, 10% on rear window and sun roof
NISMO CLEAR SIDE INDICATORS
TEIN HA ADJUSTABLE HEIGHT AND DAMPER FULL COIL-OVER SUSPENSION
NEW STANDARD ROTORS AND PERFORMANCE PADS
18INCH HP FUSION, 8.5 INCH FRONT, 9 INCH REAR +38 OFFSET
235s FRONT, 245s REAR
COMES WITH STANDARD 16's WITH HEAPS OF RUBBER DUNLOP SPORTS
WIDEBODY ROLLED FRONT GUARDS, PROFESSIONAL JOB DONE IN JAPAN
ENGINE
168,000 KM
RB25DET NEEDS WORK
(USES APPROX 0.25L OF OIL PER TANK OF FUEL)
ORIGINAL MANUAL GEARBOX IN EXCELLENT CONDITION
HIGH FLOW R34 TURBO (OP6 REAR HOUSING, RATED FOR 270RWkW)
APEXI AVCR BOOST CONTROLLER
FRONT MOUNT INTERCOOLER, PAINTED BLACK
STANDARD AIRBOX WITH K&N PANEL FILTER, ALSO HAVE K&N POD FILTER WITH ADAPTOR KIT
OIL CATCH CAN
FULL TURBO BACK HIGHFLOW EXHAUST
STAINLESS STEEL HIGH FLOW CAT-CONVERTER
STAINLESS CANNON
R33 GTR INTANK FUEL PUMP
APEXI POWER FC W/O HAND CONTROLLER, STANDARD ECU ALSO AVAILABLE
INTERIOR
SONY 50Wx4 CD HEADUNIT
12" SUBWOOFER IN BOLTED FIBERGLASS ENCLOSURE (SPARE WHEEL CAN STILL BE ACCESSED, AND ALL FACTORY BOOT CARPETS IN PLACE)
BATTERY BOX WITH LARGER BATTERY IN BOOT
JAPANESE TURBO TIMER
BLUE LED DASH
MONGOOSE 2 PT ALARM W/ 2 REMOTES
FULL SET OF S2 MESH STYLE R33 FLOORMATS
CARPET,SEATS,DASH INTERIOR IS IMMACULATE
AIRCON/CLIMATE CONTROLL
ABS BRAKES,DUEL AIRBAGS,POWER WINDOWS,MIRRORS ETC
MOMO GEAR KNOB
FACTORY S2 LUMBAR ADJUSTABLE BUCKET STYLE SEATS, SMALL TEAR IN DRIVERS SEAT, REPAIRED AND UNDER SEAT COVERS.
ISSUES
ENGINE NEEDS WORK, PUT A 30 oR SECOND HAND MOTOR AND TUNE FOR 270kW
ABS NOT WORKING
AIRBAG / STEERING WHEEL / CLOCK SPRING NEEDS TO BE RE-ALIGNED
FRONT WINDSCREEN CRACK
$9,000 WITH ALL THESE GOODIES (INCLUDING INTERCOOLER, PFC, AVCR, COIL OVERS, OP6 TURBO ETC.)
$7,000 WITHOUT PFC, OP6 TURBO, AVCR
IF NO INTEREST I WILL STRIP THE CAR DOWN AND TAKE IT TO THE WRECKERS,
WOULD BE A SHAME TO SEE THE END OF HER, WOULDNT TAKE MUCH TO START MAKING GOOD POWER
HEAPS OF REGO TILL MAY 2012,
THANKS FOR LOOKING MAKE AN OFFER !!
Pm for Number
Thanks Matt
https://www.sau.com.au/forums/topic/369776-clean-r33-going-cheap/
mad car mate, recommended it to a friend who is looking around so hope he gets in touch.
its weird but yours is almost a match to mine right down to the colour, series 2, Sony head unit, crack on the front windscreen and 235 fronts/245 rears.
small world eh.
  • 3 weeks later...
  • 4 weeks later...
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
