CHEEP CLEAN TURBO R33 -- SOO MANY GOODIES :)
CAR IS HARDLY DRIVEN NOW, ALWAYS GARRAGED
96 R33 SKYLINE SERIES 2 GTST
LOCATED IN NEWCASTLE NSW
BODY
FACTORY SILVER PAINT IN EXCELLENT CONDITION
LEGAL 35% DARK TINT, 10% on rear window and sun roof
NISMO CLEAR SIDE INDICATORS
TEIN HA ADJUSTABLE HEIGHT AND DAMPER FULL COIL-OVER SUSPENSION
NEW STANDARD ROTORS AND PERFORMANCE PADS
18INCH HP FUSION, 8.5 INCH FRONT, 9 INCH REAR +38 OFFSET
235s FRONT, 245s REAR
COMES WITH STANDARD 16's WITH HEAPS OF RUBBER DUNLOP SPORTS
WIDEBODY ROLLED FRONT GUARDS, PROFESSIONAL JOB DONE IN JAPAN
ENGINE
168,000 KM
RB25DET NEEDS WORK
(USES APPROX 0.25L OF OIL PER TANK OF FUEL)
ORIGINAL MANUAL GEARBOX IN EXCELLENT CONDITION
HIGH FLOW R34 TURBO (OP6 REAR HOUSING, RATED FOR 270RWkW)
APEXI AVCR BOOST CONTROLLER
FRONT MOUNT INTERCOOLER, PAINTED BLACK
STANDARD AIRBOX WITH K&N PANEL FILTER, ALSO HAVE K&N POD FILTER WITH ADAPTOR KIT
OIL CATCH CAN
FULL TURBO BACK HIGHFLOW EXHAUST
STAINLESS STEEL HIGH FLOW CAT-CONVERTER
STAINLESS CANNON
R33 GTR INTANK FUEL PUMP
APEXI POWER FC W/O HAND CONTROLLER, STANDARD ECU ALSO AVAILABLE
INTERIOR
SONY 50Wx4 CD HEADUNIT
12" SUBWOOFER IN BOLTED FIBERGLASS ENCLOSURE (SPARE WHEEL CAN STILL BE ACCESSED, AND ALL FACTORY BOOT CARPETS IN PLACE)
BATTERY BOX WITH LARGER BATTERY IN BOOT
JAPANESE TURBO TIMER
BLUE LED DASH
MONGOOSE 2 PT ALARM W/ 2 REMOTES
FULL SET OF S2 MESH STYLE R33 FLOORMATS
CARPET,SEATS,DASH INTERIOR IS IMMACULATE
AIRCON/CLIMATE CONTROLL
ABS BRAKES,DUEL AIRBAGS,POWER WINDOWS,MIRRORS ETC
MOMO GEAR KNOB
FACTORY S2 LUMBAR ADJUSTABLE BUCKET STYLE SEATS, SMALL TEAR IN DRIVERS SEAT, REPAIRED AND UNDER SEAT COVERS.
ISSUES
ENGINE NEEDS WORK, PUT A 30 oR SECOND HAND MOTOR AND TUNE FOR 270kW
ABS NOT WORKING
AIRBAG / STEERING WHEEL / CLOCK SPRING NEEDS TO BE RE-ALIGNED
FRONT WINDSCREEN CRACK
$9,000 WITH ALL THESE GOODIES (INCLUDING INTERCOOLER, PFC, AVCR, COIL OVERS, OP6 TURBO ETC.)
$7,000 WITHOUT PFC, OP6 TURBO, AVCR
IF NO INTEREST I WILL STRIP THE CAR DOWN AND TAKE IT TO THE WRECKERS,
WOULD BE A SHAME TO SEE THE END OF HER, WOULDNT TAKE MUCH TO START MAKING GOOD POWER
HEAPS OF REGO TILL MAY 2012,
THANKS FOR LOOKING MAKE AN OFFER !!
Pm for Number
Thanks Matt
https://www.sau.com.au/forums/topic/369776-clean-r33-going-cheap/
mad car mate, recommended it to a friend who is looking around so hope he gets in touch.
its weird but yours is almost a match to mine right down to the colour, series 2, Sony head unit, crack on the front windscreen and 235 fronts/245 rears.
small world eh.
  • 3 weeks later...
  • 4 weeks later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I鈥檇 finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I鈥檝e owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I鈥檇 love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I鈥檝e explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
