Hey guys,
I know there are heaps of people out there that has tried to take out the cigarette lighter from a R34 but just ended up being too frustrated and just broke the thing off lol.
So after spending 15mins playing around with it, I worked out how to take it off properly without breaking it. Here's the tutorial with images.
Also, if you have a blown cigarette lighter LED light, you can change it too :)
  • Like 1
but what could you replace the lighter with? :P
It wasn't about just "replacing" it lol.
I had a friend that needed to transfer his lighter from auto surround to manual surround, that's why I posted up the DIY :P
Also, it's good for people that might need to change the light bulb :D
  • 1 year later...
Hi... I know this is an old post,
But i would like to say thanks allot for this mate!
I was fighting the other day and could not get it to come out
I was afraid to break it so I just left it.
Than I said there has to be a way.
So decided to search it up and came across
This post. Its perfect man just what I needed
Thanks
Edited by BrotherHood
  • 3 months later...
haha I was struggling with this a couple of weeks ago. I was going to cut out a circle and install a gauge there.
In the end I gave up and deciding to lose the stereo as i needed more space for gauges / water meth controller and some other crap.
  • 4 months later...
  • 1 year later...
I'd love to know how to get this thing off, I tried for ages the other night and it wouldn't budge.
I only wanted to remove it for painting purposes, instead I taped it up and painted away.
  • 9 months later...
  • 2 years later...
1. Remove the lighter part (the hand-held piece with the coil)
2. Inside the barrel there should be 2 tiny squares (2mm long) about 5mm in from the top. Each tiny square is opposite the other, with a plastic tab in each. Stab each tab with a small flathead while trying to push the steel barrel out. Do this until the steel barrel sits on top of the tabs.
3. Pry the barrel out from the top (this will probably damage the plastic). Slide the barrel all the way out.
4. Pull the lighter assembly out on an angle - the LED (black square piece behind with separate plug) should act as the pivot point here. It comes out the front.
  • Like 1
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
