HELP: R33 Electric Window Winder (STUFFED)
R33_Cam
 Share
Has Anyone Ever had any trouble with an R33 Drivers window not going up or down??? im pretty sure its the motor, cause i took it apart and gave the motor a whack and it started working again.....
so my next question is:
1. Does anyone have one of these laying around, or know where
i can get one from.
2. How do you get the damn thing out!!!!, it looks pretty difficult
(Nearly Impossible) :hellpisse
Any help would be much appreciated
Pull the switch out and clean it.
It tends to get a build up of crap on the contacts.
Mine stopped working then for some reason every now and again would only work when it was raining.
Cleaned it.. Worked Perfectly Since.
Maybe look at gettings some conductive grease, to prevent the build up of crap air moisture water etc..
  • 2 months later...
Im having exactly these problems.
Bought my car '95 R33 GTS-T 10 weeks ago and the windows worked fine for about 4wks.
Then the driver side would stop/start/stop so i would just open/close the door or give a firm whack on the inside just near the up/down switches and it would work again.
Then it came good again, perfect infact.
About a week ago (the day i had my car in getting the windows tinted) it completely stopped working, i tried the whole way to the tint place to get it to work but it refuses to budge.
I'll have to pull it apart again and see if there is any dust or loose solders or anything but i really would just rather replace the part.
If ANYBODY can point me in the right direction to getting a driver side electric thingy-ma-jiggy to fix this problem please PM me immediately.
Edit: If i was to take the motor/electronic thingies out and give them to an Auto Electrician would they beable to hook some gadget up to it and find out the problem or would they need my car there as well to work it all out ?
I jad the same problem, i cleaned the switch contacts etc..
What i found the problem was, (also a probelm i had in my 180sx) is the little module (dont know the correct name) that is located near the arm rest had a dry solder joint in it...
You can see it if it has (like it has been hot and the coating on the circuit board has moved away from the solder) i touched this up with a soldering iron and some fresh solder.
Now it works fine...... :uh-huh:
sweet - sounds like a common problem with an easy fix. Now all i gotta do is fine someone that knows how to operate a Soldering Iron :(
Not too difficult...go down to Dick Smith. $20 will get you a cheapy, and maybe coupla bucks for solder. Plug it in via an extension cord, one hand on solder, other on iron, heat solder so it flows into the connection. Just being careful not to drip any excess on plastic or seats, etc (instaburn!)
Do some practice first away from the car just on some bare wires or whatever, but its easy to do. As long as the connections are fairly big (which I've always encountered on a car), its not hard to do. Very hard to screw anything up.
I took my door apart again on the weekend. The board that is attached to the switches i believe is the culprit, all other buttons work fine except for the driver side door.
I cant seem to take apart those 2 green electical boards tho, i've taken a screw out but can't seem to unlatch the other half of it.
If i post a pic of it can anybody tell me exactly which section i need to be paying particular attention to ?
Their were about 10 dirty solders but i scratched them off with my finger and the solder underneath looks fine to me although i can't see all of the electical board for the above reasons.
Any help would be great, im a driver that needs a constant air flow so my aircon is copping a hammering lately :P
I have the same problem...if I let the window go all the way to the stop (down)....it wont restart without toggling the sh%t out of the switch. I have found that if I stop the window before it goes all the way to the bottom, it will go back up no probs. I will get one of the nations finest boffins here at work to check it out and I will get back to you all.
benm...sounds like you may have scratched off the protective lacquer from the circuit board....which is no biggy, you will have to recoat after you've fixed the problem.:D
If i take that 1 component to an auto electrician will he beable to hook up something to find the fault? or would he need my entire door/car etc to beable to find the fault ?
Well it just cost me $175 today to get my left headlight fixed for my R31 because of dodgy internal switch.. so auto-elecs aren't cheap. Could be a motor problem it sounds like if it goes down like almost all the way, could be a pretty much anything problem. Sometimes i can fix stuff by looking at it - others not :D
Generally they use a multimeter to isolate the problem and work from there. If you take it to there with the door skin off they might be able to give you a quick diagnosis and give u an estimate of what needs replacing/cost. I'd leave it all intact.
Unless u can see obvious burn marks in the board it can often be difficult to track down the exact problem.
I HAD THE SAME PROBLEM, MINE WOUDLNT GO DOWN, ITS MOST LIKELY THIS BLACK MODULE, PULL THE DOOR TRIM OFF AND FOLLOW THE WIRING TO A BLACK BOX ABOUT THE SIZE OF A NOKIA MOBILE[8210], GO 2 A WRECKER THAT HAS ONE ASK IF U CAN TRY IT B4 U BY TO C IF ITS THE PROBLEM. THIS IS A COMMON PROBLEM IN THE GTST. PS.DEPENDS WHAT MODEL UV GOT, NOT ALL OF THE SKYLINES R THE SAME, EG SERIES1 OR 2
Silverskyline.....I take it this 'little black box' is not the switch module ....is it actually located within the door ????(as opposed to the door handle)....I have had the techo's look at the switch module and its definately not that....they suspect it to be some sort of microswitch or something that only engages when the window comes to a stop, as the problem only occurs (as previously explained) when the window goes right down.
  • 2 years later...
 Share
    • Nah, yeah, nah. Speakers have a nominal impedance of 8 ohm that looks more like 6.4 ohm when measured. The receiver's amplifiers (all channels) are all rated to 6 ohm (I think, it's been a long time since I cared). The real problem is that many modern class D amps have aggressive protection circuitry that cuts off the fun if they think too much current is being drawn. And with my speakers having series crossovers, as opposed to more typical parallel crossovers, and big TL enclosures, they can certainly dip down to lower impedances at some frequencies and that easily triggers the protection. Pioneer receivers are somewhat famous for it, but even Denon, Onkyo, et al, all have many complaints against them across various models. It only does it when listening to music at high levels. You have to be putting your ears at risk to do it. But sometimes I want to do that. If I was serious about using it as a listening room I'd simply upgrade the amp for the front pair to a nice Rotel or something, and just use the receiver for signal handling and processing - although that would be a bit of a pain in the arse too. Have to switch on more shit, pre-amp volume vs main amp volume, etc etc.
    • yeah pretty much, stopped playing after lightfall, couldnt be bothered with the final shape...  ran that game into the ground for years... bit of a shame.. the  story was awesome. was playing a lot of trials but the hackers became tooo much, ruined the game.
    • This is why you don't get invited to press events.         Kodi
    • For example, you’ll need this approval if: you’re a car enthusiast looking to import a specialist vehicle or an older car you want to bring your vehicle with you when you move to Australia you manufacture or import special purpose vehicles or a small number of trailers each year.       Tutuapp 9Apps
    • I reckon you are 100% right on the money. The only reason I bought Red Sport instead of the base VR30 is that I am investigating racing it in Production Cars, and they require you to run a (mostly) standard car....therefore knowing exactly what was in the RS spec was important to me and I paid the extra. Other than that, for sure I would have pocketed the $10k and spent them on mods instead. Plus the non-RS models are more likely to have had a nicer life prior. Just a warning though, mods always cost twice as much as they look like they will on paper BTW you should also consider the 400R imports, they are about the same price as a local RS but 5+ years newer. Of course that comes with the usual warnings about finding parts, unhelpful nissan dealers and finding insurance
