hi guys i recently purchased a s2 r33 96 gtst and am a bit worried about the way that it drives so il give you the story and hopefully somebody can help me.
Ok i when i got it it was LOW like on the bump stops low had aftermarket suspension KYB i think was flogged out. When i hit bumps on the road the rear of the car would kind of kick out sideways ( that i understand becuase all that energy has nowhere to go)
So to solve the problem i brought a set of genuine coilover of this forum and the guys assured me that they were mint and working perfectly.
So on the weekend me and a mate went to his workshop and fitted them (he is a mechanic) and the underbody of the car looks great and all the bushed look fine aswell.
After fitting the used genuine coilovers i was very dissapointed as the car sits fine now but the shocks are f**ked the car just bounces like crazy and going fast around a corner the rear just bounces across the road.
But here is my question when i hit bumps still the back kicks out just a little no where near as bad as when it had no suspension but still just little, and im done with seconhand shit so i brought brand new adjustable coilivers and will fit them on the weekend.
Is it possible that the rear cradle is moving sideways or just a case of rooted suspension all round, i like this skyline appart from that and i dont want nothing fancy i dont race etc or should i just sell it?
https://www.sau.com.au/forums/topic/369815-r33-bad-handling/
sounds like you bought jap coilovers that have way too stiff spring rates for our roads. there probably wasnt anything wrong with them other than that they were unsuitable for what you want them for
Na i had a look underneath it, was sitting on bumpers just wondering why back is kicking and unstable over bumps.
Get a wheel alignment. If the car was so low it was on the bump stops bfefore and now its at standard height your settings will not be the same.
Get it aligned and start again. I have a stock series 2 and it handles and rides just fine.
yes i know that, i have new coilovers and new tie rod ends going in on saturday then il get a wheel alignment on the following monday, my questions is why is the rear UNSTABLE as hell and kicking out, will new coilvers fix the problem or should i be looking elsewhere for the issue, and all the bushes are fine.
When it was super low, you would have had bump steer. That is, hit a bump and the rear wheels will actually change alignment so much it "kicks".
Now that it's raised, your rear toe and camber will be so far out, it's not properly gripping in the back, and it's just moving around.
As has been said. If the car was sitting on the bumps stops it was FAR to low for a Skyline to handle properly. Once a Skyline gets that low the suspension geometry goes to shit.
You then put in different suspension which im assuming raised the car back up? Or did you simply reuse the old springs and put in new shocks? Because that would have been pointless.
So if the car is back to normal ride height than you will now need a proper wheel alignment as you have changed the suspension geometry again.
New suspension will not fix the problem if your alignment is completely out of whack.
Also you havn't said what springs rates any of the spings were. As was mentioned, if they were Jap branded they could have been ridicolously stiff which in conjunction with a very low car would result in poor handling on the street.
raising the car will make the rear toe in
excessive toe in at the rear will make it very unstable exactly like you've described
so like what others have said
wait til you get an ALIGNMENT
problem will most likely go away
i thought excessive rear toe out would make it supre unstable, and toe in would stablise it?
or is it just any excessive toe makes a car unstable?
Yeah I thought raising the car would make it toe out and gain positive camber which would cause the problems OP is having. Either way, alignment is necessary. They're like $40, stop being a tight wad and get it done.
You'll get toe out at the front and toe in at the rear when you raise the car
Look at it this way
Both front and rear are designed to toe in under hard braking to stabilise the car
But because when you step on the brake hard, front dives, rear lifts
So nissan had to design the Front and rear geometry to act completely opposite
Yes toe in helps stabilizing it but not when it's too much
Edited by chiksluvit
i have the same issue on my car atm too (R34 GTT), i believe it is for the 2 following reasons;
1) rear shocks are dead as they are leaking (but not knocking)
2) toe needs to be adjusted as the last time i got a wheel alignment, it was out by heaps.
I had stiff coilovers before (G4s) and it handled perfectly so i dont thkn stiffness will be the cause of it.
  • 4 months later...
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
