Hi all,
A few weeks ago my battery died (obviously it was the factory one as there was not even a single word in English; all Japanese). It didnt give me any warning at all. I have already changed the battery, but some strange things happened beforehand; headlights remained on, although I had turned them off and removed the key, then they went off, but right side indicator remained on. After changing the battery, there is still one issue which has remained permanent. When I unlock the doors, side indicators start flassing (as usual), flash three or four times and normally they should go off. However in my case they remain on (both right and left side indicators). When I open the driver or passenger side doors, they go off. If I open the trunk, nothing happens (remain on). When I locked the car, everything is fine (side indicators flash a couple of times and go off.
Now the question is WHY?
Any help or info would be highly appreciated.
Cheers
https://www.sau.com.au/forums/topic/369819-flat-battery-on-ongoing-issues/
Hmm, i thought that changing the original battery is a part of compliance? Could be wrong though.
I don't know much about this but if i were you i'd try to reset the ecu ( hopefuly resets the bcm) and see what happens.Then again having the battery flat could have reset it already...:mellow:
Have you got an aftermarket immobiliser/alarm system fitted?
Thanks for your response. Could you please provide a bit more detail in regards to what ecu stands for and how to reset it. I do have an after market immobiliser fitted (it really sucks as I think it is a cheap one). However I had never had such an issue before. I have had this car for over a year, then this happened when the battery died.
Sound like it's your after market immobiliser/alarm Some have a function to turn the indicators on and keep them on untill you open the door or turn the car on.
What brand is your alarm? try different button combos like pressing your unlock button first then your lock button to lock the car or pressing your lock button twice.
To be honest I do not know what brand my immobiliser is. I guess it is a cheap one. The thing is this issue didnt happen for a year after I got this car. Rather it happened after the battery issue.
I would definetely try to press different buttons if I had more than one. this one has only one button which locks and unlocks the car.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
