  • Replies 55
Private health insurance ftw. $87 check up and clean cost me about $25 by the end.
Private health is great. had it for years.. but when you need shit done, its still f**kin pricey
i get free checkups/cleans. but everytime i go.. i need something else..
Mine are pretty good.... all original, no fillings, wisdoms out years ago.
I wish they were straighter though, I had braces as a teenager but didn't wear my retainer as much as I should and they moved :(
Used to go for 6 monthly check ups & cleaning religiously but got lazy and haven't been for ages. Should do that again. I only have Extras cover but got most of it back.
I think my parents spent like 10k on my teeth.
Had jaw expanded twice, braces, wisdoms out few fillings all white and a permanent wire on my bottom jaw but other than that I think they are pretty darn good.
I'm a bit anal when it comes to dental care. I could never go out with someone with yucky teeth.
Ummm..., how about that article on Today/Tonight Corinne, where they showed "Snapon Teeth"???
Pretty impressive! You'd never know if there were yucky teeth underneath until after the wedding day!!! :ph34r:
http://au.news.yahoo.com/today-tonight/health/article/-/7980732/perfect-teeth/
it's basically like a wearing a cap/hat while you are sweating alot..
bacteria grows
and turns acidic causing problems over time
and during the 12 hours whatever you eat and drink increases the acidity around the snap on and gives more food for the bacteria> eventually leading to more problems
as u said it... more perio problems and caries
if you were to CLEAN after everything you eat and drink? may work but "may" is not good enough haha
I get a government fund every 2 years worth around 5k. Covers all except cosmetic ie. bleaching
Protect your gums as poor gums leads to bad infections, gingervitus and then leads to your teeth decaying; ultimately periodontal disease.
I've got side impact wisdoms that will eventually need to come out... 4 figures to get it done fml!
i had the same shit... cost me 2.5k. had all 4 wisdom teeth out at once. my face swelled up like a bitch. couldnt eat nothing but yoghurt.
i had braces on as a kid and then the wisdom teeth decided to come up on the piss and push my bottom front teeth into eachother so got them out real quick. still have a wire in the bottom behind my front teeth to keep them from moving tho.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
