  • Replies 55
Private health insurance ftw. $87 check up and clean cost me about $25 by the end.
Private health is great. had it for years.. but when you need shit done, its still f**kin pricey
i get free checkups/cleans. but everytime i go.. i need something else..
Mine are pretty good.... all original, no fillings, wisdoms out years ago.
I wish they were straighter though, I had braces as a teenager but didn't wear my retainer as much as I should and they moved :(
Used to go for 6 monthly check ups & cleaning religiously but got lazy and haven't been for ages. Should do that again. I only have Extras cover but got most of it back.
I think my parents spent like 10k on my teeth.
Had jaw expanded twice, braces, wisdoms out few fillings all white and a permanent wire on my bottom jaw but other than that I think they are pretty darn good.
I'm a bit anal when it comes to dental care. I could never go out with someone with yucky teeth.
Ummm..., how about that article on Today/Tonight Corinne, where they showed "Snapon Teeth"???
Pretty impressive! You'd never know if there were yucky teeth underneath until after the wedding day!!! :ph34r:
http://au.news.yahoo.com/today-tonight/health/article/-/7980732/perfect-teeth/
it's basically like a wearing a cap/hat while you are sweating alot..
bacteria grows
and turns acidic causing problems over time
and during the 12 hours whatever you eat and drink increases the acidity around the snap on and gives more food for the bacteria> eventually leading to more problems
as u said it... more perio problems and caries
if you were to CLEAN after everything you eat and drink? may work but "may" is not good enough haha
I get a government fund every 2 years worth around 5k. Covers all except cosmetic ie. bleaching
Protect your gums as poor gums leads to bad infections, gingervitus and then leads to your teeth decaying; ultimately periodontal disease.
I've got side impact wisdoms that will eventually need to come out... 4 figures to get it done fml!
i had the same shit... cost me 2.5k. had all 4 wisdom teeth out at once. my face swelled up like a bitch. couldnt eat nothing but yoghurt.
i had braces on as a kid and then the wisdom teeth decided to come up on the piss and push my bottom front teeth into eachother so got them out real quick. still have a wire in the bottom behind my front teeth to keep them from moving tho.
    • chorus hitting me so hard.....
    • its funny you linked that video. a friend set it to me last night. i commented there, and checked SAU to see if anyone had commented on my thread and saw someone had posted. will try to help others when i can.
    • My rotisserie is due to be delivered next week and I need to get my R32 mounted on to it. I know how to mount it on the actual rotisserie but those of you that have, did you add any additional bracing to the chassis? I was planning on welding some 1x1 box section across the top of the seatbelt buckles, across the back seats and then down to the front footwells (and possible across from there also? I've also put the behind dash bar back in to give a bit more strength. Its mostly going to be the floor and sills being cut out with a little on the rear quarters
    • apparently people are still having trouble with this as well
    • Only problem with that is it's obvious to the police, but same same with the aes valve. Most people get the valve precat so it's harder to see when looking under the car from the rear.
