Ever since I had a cavity filled two or three days ago, I've had a sore tooth and been getting very light headaches around the area that it was done.
I'm wonder if the dentist could have had some sort of malpractice while working on my tooth that caused the root to become infected.
  • Replies 55
One can never be sure on a forum, but can you puts 5-10 clove oil drops on the area and take you temperature? Infections always cause a rise in body temp.
have always hated going to the dentist as they never have anything good to say. but have had some crazy toothaches of late so i have made an appointment for first week of Dec. im really not looking forward to it but its overdue.went 8-9 years without a visit and has been 2 or so since my last. no fillings and all wisdoms out. 2 teeth have broken since last appointment i think from overcrowding >_<
Certain races have small jaws/mandibles and large teeth > overcrowding.
Your parents have overcrowded teeth too?
Why does it seem that 90% of the population are freaked out going to the dentist? Bad visions as a child perhaps? Or it's the injections used when numbing for a filling or removal of teeth hahahahaha
i dont mind the needles as it helps me not feel everything else.
i hate that grinding feeling. have only had 1 tooth pulled after a hockey mishap but had already had heaps of needles so it wasnt too bad...sounded terrible though >_<
had tooth pulled an hour ago after finding my broken tooth was in pretty bad condition and might not repair well. was painfree getting it out but feels strange getting pulled around the chair by pliers.hopefully doesnt hurt too much tonight once the anaesthetic is totally worn off
also scored tomorrow off :thumbsup:
  • 10 months later...
Poor gum health in mice > severe forms of arthritis.
I'm not sure of the mechanism except for the fact that periodontal disease > breakdown of the mandible.
So might this corollary exist...
Keep your gums healthy > reduced risk of arthritis???
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
