Gtr Parts R32 - Heaps Of Good A/m Parts Available Vic
Don't want to do this but the car has sat in the shed for 2 years now and never gets driven anymore. Tough call but I've decided to start parting it. The car still has many of the parts still fitted to it and will be removed over the next few weeks. Also please don't get upset if pm's take a few days to be answered.
Pair -5 turbos $1500
Set of Michelin Pilot Slicks 18inch (about 265 wide. Need to check) $400 Lots of rubber left.
V8 supercar wing carbon fibre with machined harrop struts - White - Ex Kmart racing VT - It works - Dinted the back of my boot in at Phillip Island $600
Power FC and hand controller with tune to suit the -5's with std inj/afm $850
Set of centre gauges from R32 $50
HKS VPC. Comes with everything req'd. Use this to remove your AFM's on your gtr and still run std or pfc ecu. Allows control of fuel mixtures to make your car run safe AFR's. Uses its own Map sensor and inlet temp sensor plus all std motor sensors. $250
Set of front guard liners and front under tray. Has factory front brake ducts and I won't seperate. $150 Getting very rare!
R32 3inch exhaust with seperate de-cat pipe. Has centre muffler, no rear muffler, just straight throught to back $100
R32 GTR body fuel cap/flap missing hinge $FREE
R32 GTR G-Sensor $100
R32 GTR rear diff with 1.5 or 2 way. Need to remove it and see brand and type. Its very tight $650
OS Giken sprung centre triple plate. Was about 80% about last look. Prob only travelled 2000k since with 2 trackdays since $1750 Awesome clutch! Push type.
Full suspension setup consisting of custom valved shocks out of SK production car with adj height treaded sleeves. Springs 7kgmm and 5kgmm. Whiteline swaybars. Cusco upper arms front 3.5deg and rear adj. Tein front adj castor rods. This setup gives more confidence than you could ever imagine in a R32 GTR at the track or on the street. $2200
New R/H sill panel $100 Suit GTR/GTST
R32 R/H tail light $FREE
Pair Volk Circlar rims 18x9.5 +38mm offest. $300. These sell for around 1500-2000 set.
R32 R/H mirror $25
R33 GTR lowered rear springs for std style shocks. Sits very nice $25
R32 GTR in STI blue with 88mm HKS forged pistons, Cam gears, button clutch, chipped ecu, 100mm FMIC, new 324mm rotors and braided lines all round, Caliper spacers, new rear slotted rotors, rebuilt calipers all round, smooth g/box and tight transfer case, 320kmh Nismo speedo, Cusco strut braces, lipped out rear guards, 3.5 inch exhaust plus more. Complied and previously registered with no defects. Perfect start to a quick daily or start of track car. $13000neg
Melbourne 40 min south of city or can meet at Moorabbin Airport duding work hours. Happy to post.
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 5 months later...
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
