I ran my car in an event today. The first with my R33 GTR.
The car seemed to have a bit of understeer yet on one corner oversteer.
Can someone advise what would be the next step to make the car handle better?
First thing would be tyres as you can hear tyre squeel from the attached video (no one else's tyres seemed to squeel like mine so maybe they're a bit hard)
The car currently has
Tien flex coilovers with incar adjustment
LMGT1 18x10.5" wheels fitted with 265.35.ZR18 Continental Contactsport2 tyres
I only had 4 runs so purposely left the shocks on their softest setting while i got used to the car.
(maybe i should have stiffened up the front)
http://s88.photobucket.com/albums/k199/Aussie109/?action=view&current=MVI_1718.mp4
Any advice most welcome
https://www.sau.com.au/forums/topic/369855-r33-gtr-handling/
Ad as much castor as you can with either you stock arms or aftermarket, that will help, maybe try swaybars and a camber kit on the front.
Gtr's will always understeer especially corner entry no matter what you do, just depends on how hard you push it into a corner.
I had this same issue on my gtst, but I found after upgrading to whiteline sway bars and a new front strut brace at the next track day I had virtually no understeer and a tiny amount of nice controllable oversteer. Definitely worth upgrading, very cheap and make a heap of difference :)
Get a wheel alignment first and see where all the geometry is. Get all bushes and ball joints inspected to see if they are all good. That is a good start.
+1
Start from the basic and work on it from there. You might have your questions answered as to "why" with a simple run up.
The only issue with alignments, try find somewhere decent. Often a lot of machines are not "true" as they are never checked/serviced properly. I've had varying readings from 2 places on the same day as an example (which is correct? hard to say). So a motorsport oriented place is where i would start and not somewhere like a bob jane
Having gone the whole hog on my suspension, looking back my assessment would be that the best value for money to improve handling would be tyre pressures, bushes and camber adjustment (in that order). The other bits definitely make a difference, but cost to improvement ratio starts going up exponentially.
Couple of good (and bad) motorsport oriented places in WA I've used. PM for details, if you want.
Cheers
Jack
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
