Hi,
Up for grabs is an AS NEW XBOX 360 250gb and Call Of Duty Black Ops game
This console was literally only used for a couple of hours.
I initially bought this to use when the PS3 network was down but it was shortly back up after i purchased the console.
It is literally brand new, you will not find a scratch on it.
It comes with 3 year warranty from the day its purchased. So you will have another 2 years and 10 months until the warranty expires. (receipt will be provided)
I also have another exact same console with blacks ops purchased on the same day if anyone wanted to purchase two consoles.
Pick up is available from St Albans, 30mins West of Melbourne CBD
Or i can post it out at your expense, should be $20 but just msg me first.
Asking price $450
Thanks , Ron
0432 544 363
Edited by RJ06
  • 4 weeks later...
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
