Hey Guys,
Up for sale is my 2.5" split dump and front pipe which recently came off of my Rs four S Stagea due to a upgrade. These items are great for a stock appearance with exceptionally very good power compared to the oem exhaust, Great for cutting down those DB while maintaining a good exhaust flow .
Asking $220 posted at my expense.
Best regards Chris.
Sits very nicely in the exhaust tunnel not too low and not too high, i agree front pipe is a little rough but hey... it works and fits fine
  • 3 weeks later...
