Ive tried a few pad combinations on my Sumitomo calipers without noise issues.
Have you pretensioned the spring plates that fit between the 2 pins over the top, they are designed to apply pressure on to the top of the pads and hold them down to assist stopping noise.
With time and heat they lose tension and a little bend back into shape for more pressure helps, also make sure the hump on them is pointing in the direction the rotors turn.
One other trick is to chamfer both edges of the pads with a 45 degree cut, this gives the pads a smoother contact ramp, but as said you need a few hundred Km to allow the pads to spread a layer of material on to the rotors.
I used EBC green stuff and now use Red Stuff Ceramic compound without issues on my Sumitomos with the stick on backing plate supplied with the pads, not a sound to be heard and they are rated to around 650 degrees. no need to chafer them, just drop them straight in....
  • Replies 43
Its been about a thousand km's on fresh surface rotors. Still noisy as f**k. Very consistent noise too. Sometimes noise in the morning the first instance you use the brake, noise when they are warm, and noise when they are hot. I'm ordering new pads. I already tried a chamfer on the edges, no luck. My retainers and clips are brand spanking new from Nissan.
Edited by SargeRX8
Im going to give mine another crack this weekend.
Got some new rubber shims and synthetic grease. Will give the spring thingy a bit of tension too, thats a great idea.
I remember removing it for the first time and almost lost an arm if flew out so fast lol.
I done that too lol, I twisted the pin with a screw driver to loosen it and the damn thing flung out.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
