Hi Guys and Girls,
I made a promise to one of the SAU VIC members that if we could use his car as a demonstration vehicle at a recent detailing Clinic for SAU members, I would detail up the car for him.
Well, lucky for me (and him) he took the bait and we finally got round to doing the car a few months ago.
So here we go...
First we foamed the car with CarPro Iron X Soap Gel to break down any contaminants on the paint surface and dissolve any iron fallout embedded in the paint.
We didn't just use Iron X as we wanted to give the car a good clean at the same time. Here it is left to dwell and do its thing on the vehicle.
The car was then clayed to remove any residue contamination and make the paint feel silky smooth.
Next was a proper wash using a variety or brushes to get out any old wax and polish left from previous Detailers.
The car wash then foamed again, this time with a mix of All Purpose Cleaner and Car Wash to strip off any remaining waxes and protection on the paint.
We dried up the car and masked it up to protect rubbers, edges of panels and other delicate parts of the car.
Now we can see the Swirls that we hiding under the contaminants and old protection layer.
The car was then polished using a rotary polisher, Lake Country Kompressor Pads and Menzerna Polishes. Here is the front quarter straight after the paint correction and jeweling step.
We then applied Wolfang Deep Gloss Sealant 3.0 to give both protection and warm glow to the finish.
This looked good but we wanted more depth out of this custom respray so we then topped the sealant with Pinnacle Signature Series 2 Wax.
https://www.sau.com.au/forums/topic/369938-detailed-r33-skyline/
Great Job Antonio.How do you find the kompressor pads? I find the can cut alot quicker than their standard "equivalent" I'm addicted to the constant pressures unless do a heavy cut.
How long did you leave between coats on the wax?
Regards,
Mitch
Wow, that is amazing. Love the cars styling too. That red and the bonnet look mint. I miss my CF bonnet :( Come to Sydney and do my car or if anyone here can recommend any details in Sydney who will do a top notch job, please PM me. How much does this type of job usually cost?
Edited by SargeRX8
check out detailparadise.com.au there are some from syd on there.
Edited by immacreflections
the pads can be quite abrasive on plastics and no doubt rubbers too..
I polished my ute with them for practice and didnt mask it up..I ended up with fine scratches in some of my plastic chrome work ..also it has an unpainted black plastic bumper that has some swirls marks in it now that I cant seem to clean out....good thing I practiced on my work ute hey :)
On a side not these polishers are GREAT at cleaning up yellowing headlights..Dont ever sand your headlights with sandpaper, get someone with a polisher to do it and they come out looking brand new without scratches that sandpaper leaves..I think i just used a power gloss and a power finish, ..wiped them down with windex and coated them with proper UV sealant..wish I had taken before photos but heres a quik pik.
I imagine Antonia
(or any more qualified detailer) may have different advice and the pads I used were probably a bit to abrasive a really soft one would be better ,but it worked really well for my old lights which were yellow as any..
Ah ok I missed the part where he said he was using a rotary to polish, I do mine by hand and am extra careful around those parts.
Thanks :cheers:
Edited by Dani Boi
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
