Hi guys, I have for sale 1996 Nissan Skyline Gts-t series 2. I purchased this car about 9 months ago and only selling due to buying a 4wd. Here are some details:
5 speed manual
white exterior, grey interior
109,000 kms
Front mount intercooler
Adjustable coil over suspension
front and rear sway bar
heavy duty clutch
Greddy turbo timer
dual stage electronic boost controller
Mongooose m80 alarm with keyless entry
HID headlights
18" wheels
3 inch exhaust
Hks ssqv bov
Tv/dvd with gps and reverse camera
Clarion sub and amp
yellow jacket coils (just fitted with new plugs)
Comes with 6 months rego
Recently passed inspection as is
open to offers $10,500 ono
Pictures to come later this week
https://www.sau.com.au/forums/topic/370002-act-96-r33-gts-t-series-2/
  • 4 weeks later...
  • 8 months later...
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
