freebaggin: what injectors are you using?
how much did they cost?
Sard 550cc/min. I got them for a special price but I generally bank on about $1000 from Greenline:
http://www.greenline.jp/catalogue/bcpartli...ntake=FI#engine
or Nengun.
If unlucky might also have to pay for import duty, extra $300??
  • Replies 58
gobiz - I cant remember exactly so perhaps he (or others who know) could correct me here. I believe he ended up with near 300rwkw after all modifications including - lots of head work, bump pipe and screemer pipe, rebuilt block (cant remember the specs) and his hybrid turbo.
Anyone else know any more or can correct my figures??
rbs13,
Yep mate my turbo uses a VL style T3 exh housing, I think Freebaggin's uses the same VL T3 style housing too? I'd say my turbo combo wouldn't be too bad on an RB20DET. Naturally it'd be laggier. You'd certainly have boost by 3500-4000 though.
On the dyno, thanks to a leaking BOV, I've "only" used ~1.35bar. I have ran as high as 1.7bar (not record any dyno numbers on this much boost though) The latest drag passes were using 1.35-1.38bar
4door,
No mate my turbo uses the VLT T3 ext housing (as per above) with a Garrett core and T04E housing. It was built by Precision Turbochargers to a Vince Rigoli spec.
Yeah I don't know how Matt's and my turbo were like compared to each other. Pity he wasn't still in Adelaide when we had the SA SAU dyno day a month or so back!
I haven't heard how his new engine went power wise? By the sounds of things quite well (300rwkw) !
Hi guys, sorry it took me a while to get around to this thread....
Overdriving injectors 10% in flow has had no bad effects that I have experienced. Some people do it 30% and don’t have a problem. I asked a Bosch engineer if 10% was OK and he said that would be no problem with their injectors. But it is relevant to how much boost you run. Remember you are running a base pressure that is 25% (to achieve a 10% increase in flow) over standard may not be a problem at 1.2 bar.
Injectors are usually rated at around 70 psi
Standard = Base pressure 38 psi + boost 12 psi = 50 psi
You have 20 psi capacity left.
Modified = base pressure 47 psi (+25%) + boost 18 psi (1.2 bar) = 65 psi
Leaving 5 psi capacity
But if you turn the boost up to 22 psi (1.5 bar) you have no capacity left and the injectors may leak and/or have poor spray patterns at that pressure. It is the total pressure that matters not the base pressure.
So I think quite a few people link injectors capacity directly to horsepower, like 370 cc = 370 bhp = 225 rwkw. This is not a bad rule of thumb. Then I say +10% is OK, so there is a presumption that 250 rwkw (225 + 10%) is OK on standard injectors. But the reality is it's not OK if the boost (needed to make 250 rwkw) is high enough to require you to exceed the pressure control limit of the injector.
The next issue is rpm, as the rpm rises the injector has less time stay open (and flow fuel). So this reduces the effective capacity of the injector. Say 370 cc per minute is the rating at 7,500 rpm. If you increase the requirement from the injector to 8,500 rpm then you need a 420 cc injector to keep the same flow rate per engine rpm.
Tuning tip, turn up the pressure on the dyno to a level that supplies the engine with enough fuel. Then check the base pressure, if it is under 50 psi I always feel comfortable that the injectors can cope. If not I buy bigger injectors. The Bosch pumps are rated at 73.5 psi so they can handle it as well.
Someone earlier on said injector spray pattern/flow was the problem with broken ring lands, not tuning. I totally disagree, if the tuner knew their stuff they would recognise excessive load on the injectors as per above and tune the engine appropriately. My preferred alternative is to say to the owner, "you have reached the power limit of the injectors" + "I recommend we stop at this (safe power level) until you get a set of larger injectors".
Hope that helps
4-door sleeper: I've sent an email to Tim, will update you.
Still haven't heard Sydneykid's, Steve's and others opinions re:this turbo.
What do you guys think?
OK gobiz, lets have a look at this piece, by piece...
1. GT30/40 internal gate Garrett hybrid
Yep, needs a spacer on the exhaust manifold to turbo flange and all the pipework (compressor inlet & outlet, turbine dump, oil and water feed) fabricated. None of the standard stuff does the job properly and the fabrication is tricky and not for the inexperienced as it is such a tight fit.
2. With conservative tune it has 253rwkW at 1.15 bar
Big deal, what's the average power from 4,500 rpm to 7,500 rpm?
3. with stock inlet and exh manifold
No problems with the inlet manifold, it has at least another 50 rwkw in it.
Exhaust manifold is the issue, it's an ever increasing restriction over 220 rwkw.
4. stock throttle body
Ditto inlet manifold
5. stock cams
What's the response like?
6. no cam gears
Well you can only fit one if you want to keep the VVT. There is some max power increase from the exhaust cam timing changes, but the big improvement, if you tune it right, is in response and average power.
7. 550cc injectors
Good idea
8. Microtech
Not my favourite, see other threads (search "Sydneykid" and "Microtech").
9. FMIC."
What size? And the pipework?
I have used this spec GT3040 for 320 rwkw at 1.4 bar, the compressor is rated at 55 lbs per minute of airflow and it was externally wastegated on a fabricated manifold.
0.63 A/R Turbine Housing
0.70 A/R Compressor Housing
56 Trim Compressor Wheel
55 lbs/min Comp Flow Max
So I see no real problem with making 253 rwkw at 1.15 bar, but there are other issues. The main thing is how fast is it? If it has lousy average power over the used rpm range, it will be slow. And how "nice" is it to drive? Personally I hate driving a Skyline that doesn't run nice all the time and respond when I put my foot down.
So more info is required, before I can give a "real" opinion.
6. Cam gears - the standard NVCS "inlet" gear can be adjusted anyway.
I'm sure a few people have already had a look at this dyno sheet but below is the back-to-back comparison (same dyno, same day) btw a GT3040 (internal gate) a HKS GT2835ProS, HKS GT3037S and my bitza T3/T4:
Freebaggin - GT3040
Grepin - HKS GT2835ProS
whatsisname - T3/T4
Steve - HKS 3037S
Other things to consider:
Whatsisname - boost 1.4 bar? Nice aggressive tuning due to lower comp & forged pistons
Grepin - 1.3 bar, fabricated tubular exh manifold, 85mm throttle body, Greddy plenum, 90mm thick FMIC
Steve - 1.4 bar?? HKS 256/264 cams, 0.87 exh A/R, exh wastegate, tubular exh man, lower comp via head gasket (more aggressive tuning?), cam gears, Greddy plenum
Interesting numbers relative to mods.
SK, all done in fourth gear.
Turbo doesn't need spacer due to 0.6 A/R comp housing.
FMIC 75mm X 300mm X 480mm, 2.5" pipework I think (i've seen much bigger on Tilbrook cars for eg)
Car is faster, but doey under 3000rpm, power band is smaller than before however but car faster overall for sure.
Very happy with Microtech personally.
Next step for me is Tomie Poncam as per SK suggestions and tubular exh manifold, I hope for 15% power increase in mid range and maybe 10% up top. Should get nicer spread of torque/power.
Also check pressure drops associated with pipework and FMIC.
Lach,
I had ~1.35bar on board for the power run above. It was limited by the leaking BOV :P , even after we tightened the crap out of it. My tune isn't too aggressive, total timing is only 2 degrees above stock.
EDIT: Oops... forgot to add... I couldn't agree more with Freebaggin re the Microtech LT12. I'm absolutely amazed at how well it runs my car!
I love the LT12 and the options it gives me. To be totally honest I was expect it to be a POS given the bagging people seem to give Microtech, boy was I wrong!
Maybe I'm a tad selfish, but I hope people continue to bag Microtech, that way they'll keep the prices down and work hard to make as many low cost features and upgrades as possible :D
Freebaggin,
I hope you know I'm keeping a close eye on how well your internal gated turbo goes. :thumbsup:
What sort of boost are u running?
The other week I think I saw you pulling up at a set of lights down south (u were turning right). I saw you do the finger wave on the steering wheel but I was in a bit of a daze. :D ?!? was u?
Freebaggin,
I hope you know I'm keeping a close eye on how well your internal gated turbo goes. :D
Wasn't me mate, don't work down south anymore.
I run from 0.7 to 1.2 bar, which is 215-265rwkW peak power. Being internal gate also helps with cops I think re defecting.
For you, I'd see if I can get the same ext housing as used on the XR6T. I called Garrett once and from memory they'll sell you one. It's 1.06 A/R and has same design as the nice ProS HKS internal gate turbos. A/R too big for 2.5L when combined with the compressor size on GT3040, but tor a 3L motor it would be perfect :burnout:
No mate, 4th.
Hi guys, would I be right in saying that (at 27 kph per 1,000 rpm) all of them are running out of breath at 6,666 rpm (180 kph). Most have topped out their power by 5,925 rpm (160 kph).
How about that, despite the differences in mods and tune, all the cars have ~75 rwkw at 80 kph.
Average power looks like;
RPM--------KPH--------Steve----What-------Grepin-----Free
6,667------180--------275--------265--------270--------255
5,926------160--------295--------280--------265--------265
5,185------140--------290--------265--------240--------230
4,444------120--------255--------230--------210--------215
3,704------100--------115--------150--------165--------120
Average---------------246--------238---------230--------217
Very interesting.
Very interesting.
Good stuff SK, wierd than all have power drop off at high RPM (peak power below 6000rpm) except Grepin but then again, Steve's threshhold is alot higher with ~300rwkW, so a v.good result really.
Don't want to give excuses but I forgot I had my boost controller safety set a tad low (didn't realise until after!) and when 100% throttle from 2000rpm, when turbo cut in the thing was spiking back to 0.7bar from 1.2bar so the runs were done with easy ramp up. Previous dyno runs done at on same dyno at 1.2b, the boost curve is a tad better with a bit more power from 3500rpm.
I'll redo from previous run at 1.2bar:
RPM--------KPH---Steve (1.4b?)-What(1.35b)-Grepin(1.3b)-Free(1.2b)
5,185------140--------290--------265--------240--------236
4,444------120--------255--------230--------210--------216
3,704------100--------115--------150--------165--------126
Average---------------246--------238---------230-------220
Well, not much difference really, however with with EBC safety reset and boost upped to 1.3 bar (+octane booster) from 1.2bar I reckon it will get some nicer ave numbers.
For what it's worth, here is my prediction of the incremental increase in power when I add on the Tomei PONCAMS and nicer tubular exhaust manifold.
More mid-range from cams.
More top-end from exh manifold.
What do ya think?
Wow, those are some nice curves freebaggin. :boobies2:
I contacted Tim at HPIAbox bout your turbo, I'm afraid I won't be able to afford his price.(exchange rate very poor for me at the mo)
On the up side, I found a local turbo engineering place.
He quoted a very good price for this T3/T4 hybrid:
Compressor housing a/r .70, wheel 56mm
Turbine housing a/r .84, wheel 58mm
It's internal gated and I know it's not BB, but I don't mind.
He said it's rated at 500hp.
What do you think? :sadam:
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
