Carbon Trunk Dry Fit
domino_z
 Share
Hi guys
Just came back from panel shop to give ok to paint the trunk
Pics are dry fit only, the latch still needs to be screwed on to pull it down, but so far very impressed with the fitment and panel gaps
Believe im the first in Aus with this trunk......woot woot
Trunk makes the car look alot cleaner imo
And for those that will cry "aero", i dont track, i just get stuck in traffic.......with the occasional mountain blast
Edited by domino_z
Hi guys
That's not a car - - - that's a stealth fighter!!!!!!!!!!!!!!!!
Great.
thanks guys
im really liking the wingless look, ive always wanted to do it since buying the car
re exhaust, i took a big gamble buying this sight unseen, but upon opening the box was very impressed with the welds and overall quality
the tips are from garage active
painted pics.......
zele skirt fitment is ok, they are a little short on the ends, but sit very flush with the guards
we couldnt re-use the bump stops - with them mounted you really needed to slam the boot hard to depress them and get the lock to latch. I just need to be careful closing the boot on windy days
the exhaust was made by GZY in mainland China and bought it direct from them with no markup
i was lucky that they had one in stock otherwise they will only manufacture in bulk numbers, and they do for a some well known tuners/brands
afaik they are out of stock now
wheels are 21x10.5f and 11.5r
Edited by domino_z
is it possible to cut/file down the bump rubbers so they are smaller but can still be used? might be a good idea if possible.
love the overall look but surprised about the skirt fitment. that little step at the front would annoy the hell out of me.
with the wheels, boot etc the car now looks more like an exotic. :)
i too was suprised with the fitment, afterall these are expensive genuine zele japanese made parts
but ive been told they're all the same, and looking at the bowed out sides of the stillen skirts, im glad i went with the zeles
Edited by domino_z
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
