Hi folks,
Up for sale are my beloved Simmons fr's :ermm:
They are 18x8 front and 18x9 rear. Offsets are around the +35 mark so suited to gtst's. In great condition, except for one of the fronts has some very minor rash (close up pic included)
$3000 ono
CES racing split dump pipe to suit standard turbo or turbo in stock condition. Selling as that car now has high mount.
$300
Standard rb25det exhaust manifold. have the heat shield as well if you want it.
$45
2x Turbosmart boost T's. 1 is black the other is blue.
$50 each
R33 speed sensor that goes into the gearbox. Have no use for it as I put a 25 box in my r32.
$50
Standard r32 gtst wing off my 2 door. It's black...
$50
R33 gtst standard ecu - Series 1 I think.
$50
R32 standard air box with high flow panel filter. (K&N I think)
$50
R33 series 1 AFM. Was working when I replaced it with a Z32, hasn't been used in about 12 months though.
$40
Pick up only for large items. Contact via PM or text me on 0416100051
Cheers,
Jock
https://www.sau.com.au/forums/topic/370045-18-simmons-frs/
  • 4 weeks later...
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
    • I managed to get the foam will the original upholstery off in one piece, so will be an easy to re fit thankfully.
    • Then eventually someone in a Tiguan MK2 with an email toon and some random Alibaba pipes. (FWIW, I ran a 12.9s down the 1/4 in the wife's car)
    • Not much. It's barely more than an hour's labour. So that-ish plus a boot, clamp strap, some grease.   But, being an R32 GTR, when it is up in the air and the driveshaft is out, about $9k worth of other problems will become visible.
    • Yes, as above. The welding is an easy enough job. Proper reupholstering, perhaps less so. These, and pretty much all seats of the same era (and probably still) rely on molded foam parts to make the shapes. That foam is the yellow detritus visible in the photos. And it is difficult to replicate. I didn't want the pain, so went aftermarket seats instead. But for "saving a classic".... it's probably worth the kidney and left nut that a trimmer will want to redo them.
