Just been replacing my hicas ball joints while on the car. Got both out finally with a 3 claw puller. Then made a little concoction of spacers and bolts to pull the new ones in. Had 3mm to go on the last one and then my bolt snapped inside the ball joint. Pretty devo.
Now just waiting on my new hicas inner tie rods from just jap.
Then off to Risking's for another wheel alignment.
Have u guys replaced these while on the car before?
https://www.sau.com.au/forums/topic/370076-hicas-ball-joints-r32-gtr/
i actualy had my hicas ball joints/tie rod end knuckles changed end of last year at East Coast Suspensions.
never was game enough to attemp this myself. would it be easyier to change while these are off the car so you can use a press to squeeze them on and off?
It is heaps easier to just give it to someone else to do lol.
If i could get my driveshafts out of the hubs i would have taken them off.
Had a prick of a time doing these, had to drill out and use a screw extractor to get snapped bolt out of ball joint. Then i had heaps of trouble pressing the ball joint in far enough using the centre bolt on the back of it so i had to make up a rig with 2 plates and 2 long m12 bolts and use that as a clamp to press it in.
Would help everyone else out. I have finished mine now.
Involved making a custom clamp type puller to install the new ball joint.
Not much info on replacing these so any help for others would be good.
I will post pics when im back at my laptop this arvo
oxy or gas torch. 5 mins a side :)
heat up till grease starts melting/smoking. slide hammer with a m10x1.25 nut on the end of it. 1 sharp pull out she comes. more heat slide the new one in by hand. put the 12mm bolt back on. done..
with out heat (heat gun is not enough) you will be struggling and probably damage the knuckle or the new joint on instalation. ive done lots and lots. this is the best and easiest way.
Done it with the rear uprights removed... c**t of a job. You have not lived (or wanted to kill yourself so badly) until you have done subframe bushes :)
To add insult to injury they are expensive from Nissan!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
