Definitely need to know what turbo youve got before you can select a housing. You may find replacing the housing will fall short in benefit to replacing the whole turbo.
Can you please state what your aim of changing the housing is so we can comment on a better solution if possible?
Also, not knowing your turbos actual spec gives me the impression it may be a cheaply made thing and you could be blowing hard earned dollars in the wrong way. There are many options around the $1k mark these days that will easily replace what you have and possibly exceed your aims for the change.. Chances are buying a garrett housing OR moddifying another one to suit your 'hybrid' turbo will cost similar money and wont necessarily hold the gains you seek.
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900241
And inducer/exducer refer to the smallest and largest diameters of the wheel in question respectively. Irrespective of compressor or turbine.
Just to clarify.
you sure bout that? isnt the inducer the diameter that draws the air/gas in and exducer the diameter that expels the air/gas?? so the 60mm being talked about is the turbine inducer diameter isnt it??
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900264
Nag its not a cheap setup the previous owner spent 3500 on getting the turbo custom made buy a bloke here reason I'm changing is cause it was on an Sr20 and its now going on a 26/30 so going a bigger rear and also I have a twin scroll manifold so need a housing to suit that forgot to get turbo today so I will get it tomorrow and take some measurements
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900558
Yea thats how I have an understanding of it
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900563
so took a better measurement before didnt have the right tool before was just going bye eye n a ruler lol
turns out i have a 66mm inducer and a 56mm exducer cant seem to find any info on the as to what rear housing to buy anyone got any ideas?
been having a look around and the garret t31 housing i have on there atm soom to suit gt30/gt35 and its definetly a bigger than 60mm wheel (gt30) so im guessing it has to be a housing to suit gt35?
Edited by t04z
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5905830
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
