Definitely need to know what turbo youve got before you can select a housing. You may find replacing the housing will fall short in benefit to replacing the whole turbo.
Can you please state what your aim of changing the housing is so we can comment on a better solution if possible?
Also, not knowing your turbos actual spec gives me the impression it may be a cheaply made thing and you could be blowing hard earned dollars in the wrong way. There are many options around the $1k mark these days that will easily replace what you have and possibly exceed your aims for the change.. Chances are buying a garrett housing OR moddifying another one to suit your 'hybrid' turbo will cost similar money and wont necessarily hold the gains you seek.
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900241
And inducer/exducer refer to the smallest and largest diameters of the wheel in question respectively. Irrespective of compressor or turbine.
Just to clarify.
you sure bout that? isnt the inducer the diameter that draws the air/gas in and exducer the diameter that expels the air/gas?? so the 60mm being talked about is the turbine inducer diameter isnt it??
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900264
Nag its not a cheap setup the previous owner spent 3500 on getting the turbo custom made buy a bloke here reason I'm changing is cause it was on an Sr20 and its now going on a 26/30 so going a bigger rear and also I have a twin scroll manifold so need a housing to suit that forgot to get turbo today so I will get it tomorrow and take some measurements
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900558
Yea thats how I have an understanding of it
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5900563
so took a better measurement before didnt have the right tool before was just going bye eye n a ruler lol
turns out i have a 66mm inducer and a 56mm exducer cant seem to find any info on the as to what rear housing to buy anyone got any ideas?
been having a look around and the garret t31 housing i have on there atm soom to suit gt30/gt35 and its definetly a bigger than 60mm wheel (gt30) so im guessing it has to be a housing to suit gt35?
Edited by t04z
https://www.sau.com.au/forums/topic/370081-rear-housing/#findComment-5905830
    • So you're now accepting offers of 10% more than the cost of the turbo kit fitted?
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
