hi im just wondering if anybody would be able to help me i have just installed my sub and amp in my boot and i did all the wirring correctly and tested it all out and both amp sub and headunit was working so i decided to put my headunit back in its place, because i knew it was working, so i put it all back together and thought i should test it again to see if its working still.
so as i turned my car on my head unit stopped working? any thoughts of what it could be
your help would be greatly appreciated
Dave
https://www.sau.com.au/forums/topic/370084-my-headunit-stopped-working/
what else doesnt work on the car now, cig lighter, dome light ? dash lights , clock ?
you grounded it to the dash lights ? dash light wires show ground until you turn them on then the go to 12volts, ????
no ground at all?
no power when switched on ? accesory lead fuse or what you attached it too
no memory to hold channels or clock even on the deck ? blown fuse on constant power lead or what its attached too
fried the antenna/amp turn on lead and deck
blown fuse on any of the above ?
