going to replace my stock clutch, flywheel, spiggot bearing, thrust bearing, and clutch fork pivot.
im saving for exedy hd cusion button clutch, exedy lightweight flywheel, and nismo pivot.
i did a transit van clutch yesterday at work, to get the spiggot bearing out i drilled a hole in the back and slide hammered it out, can i do the same on my gts4?
https://www.sau.com.au/forums/topic/370086-removing-spiggot-bearing/
If you do a search this has been discussed before - most recommend packing the area with grease then hammering a shaft that's the same diameter as the spigot hole into it, which makes the grease push the back of the spigot and it should pop out. Didnt work for me tho....
someone told me about the grease method but really didnt like the sound of that so i tried my own way, worked well tho i think im going to get a clutch alignment tool and bearing puller... cos not all bearings will be the same
ive decided im going to do the rear main seal while the box is out too.
i have been driving around with the clutch slip for awhile now, only slips once the car heats up anything and around 4500-5000 rpm it starts to slip and rev out, would this be doing my engine and gearbox any damage?
i got another transit job.. this one has a leaky rear main seal, and a ASM box and i have to do it on the ground... fml
i just want to work on my car
i find quickest and easiest way is CARFULLY die grind the bush until its very thin with a die grinder and metal burr, then just a few taps with a hammer and screwdriver will split it into pieces, take the bits out with long nose pliers, use the air gun to blow out any swarf, done. probably takes 5-10 min to take your time, as you obviously don't want to be grinding your crank away with the die grinder
yeah man, the slide hammer of death haha.
ill try hook the slide hammer in there and get it out other wise i can cut it out, or bash it out with grease.
gonna get light flywheel, cusion button, rear main seal, bell housing/engine gasket, spiggot & thrust bearings, nismo clutch fork pivot. is there anything im missing?
yeah thanks people.
i noticed the replacement item is a bush not a bearing?
if thats the cased i will have to remove it with the grease packing method or grind through it and cave it in
Well its a bush (aka plain aka journal) bearing, just not a roller bearing. You can get roller spigots, but i've heard they're not reliable. Its also made from sintered bronze, so its full of tiny holes, and the holes are used hold lubricant.
Nah, thats a good list (if you like button clutches...:). Some suggest doing the gearbox input shaft seal, but i didnt bother. What's the bellhousing/engine gasket? I think you may be assuming there's something there that inst!
i use wet cardboard in the same manor and it worked every time without fail
