going to replace my stock clutch, flywheel, spiggot bearing, thrust bearing, and clutch fork pivot.
im saving for exedy hd cusion button clutch, exedy lightweight flywheel, and nismo pivot.
i did a transit van clutch yesterday at work, to get the spiggot bearing out i drilled a hole in the back and slide hammered it out, can i do the same on my gts4?
If you do a search this has been discussed before - most recommend packing the area with grease then hammering a shaft that's the same diameter as the spigot hole into it, which makes the grease push the back of the spigot and it should pop out. Didnt work for me tho....
someone told me about the grease method but really didnt like the sound of that so i tried my own way, worked well tho i think im going to get a clutch alignment tool and bearing puller... cos not all bearings will be the same
ive decided im going to do the rear main seal while the box is out too.
i have been driving around with the clutch slip for awhile now, only slips once the car heats up anything and around 4500-5000 rpm it starts to slip and rev out, would this be doing my engine and gearbox any damage?
i got another transit job.. this one has a leaky rear main seal, and a ASM box and i have to do it on the ground... fml
i just want to work on my car
i find quickest and easiest way is CARFULLY die grind the bush until its very thin with a die grinder and metal burr, then just a few taps with a hammer and screwdriver will split it into pieces, take the bits out with long nose pliers, use the air gun to blow out any swarf, done. probably takes 5-10 min to take your time, as you obviously don't want to be grinding your crank away with the die grinder
i made my own puller for spigot bushes, it should slide out easily just need a hook of some description welded to the end of a bit of bar with a big lump of steel sliding on it!
yeah man, the slide hammer of death haha.
ill try hook the slide hammer in there and get it out other wise i can cut it out, or bash it out with grease.
gonna get light flywheel, cusion button, rear main seal, bell housing/engine gasket, spiggot & thrust bearings, nismo clutch fork pivot. is there anything im missing?
yeah thanks people.
i noticed the replacement item is a bush not a bearing?
if thats the cased i will have to remove it with the grease packing method or grind through it and cave it in
Well its a bush (aka plain aka journal) bearing, just not a roller bearing. You can get roller spigots, but i've heard they're not reliable. Its also made from sintered bronze, so its full of tiny holes, and the holes are used hold lubricant.
Nah, thats a good list (if you like button clutches...:). Some suggest doing the gearbox input shaft seal, but i didnt bother. What's the bellhousing/engine gasket? I think you may be assuming there's something there that inst!
bought my clutch and seal kit yesterday :D exedy hd solid button clutch, and seal kit <----- i was talking about check it out :D next pay fork pivot and flywheel.
anyone know of a good flywheel that will go good with button clutch????
i use wet cardboard in the same manor and it worked every time without fail
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
