Came across deal of the century on some V35 EL gauges. These are out of the USA and cost an unbelievable US$58 delivered.
http://www.ebay.com.au/itm/03-04-G35-MANUAL-A-D-D-Angel-Gauge-Gauges-INFINITI-/200625226623?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb632037f
Arrived in a few days from paying and fitted them today - they are freaking awesome!!!!
They are to suit a 260km/h speedo (for the inner km/h bit), but conveniently the MPH scale on the outside goes to 160mph, so is not dissimilar to the V35 180km/h max speed. And especially since my speedo used to run around 10% off (due to my 265/35 tyres), this works out perfectly - the MPH speed almost perfectly matches my km/h speed.
Took under 1.5 hours complete to install from go to woah, having never removed a cluster before. Trickiest bit was getting the EL thingo over the gauge needles - but got there eventually.
Enjoy the pics.
https://www.sau.com.au/forums/topic/370094-v35-el-gauges/
Yeah except their normal price is US$119 + shipping - these are less than half of that. I thought about colouring in the MPH references and the km/h around the inside with black texta/paint - pretty sure you would never notice it. But I have left them for now, as I think the extra numbers make it look more 'racelike'.
https://www.sau.com.au/forums/topic/370094-v35-el-gauges/#findComment-5899228
Looks the goods! Can't wait to install my nismo dash now!!!
You should have done a DIY to pulling the cluster out....
Ask and you shall receive ...
http://infinitihelp.com/diy/gcoupe/projects/infiniti_g35_instrument_cluster_removal_procedure.htm
https://www.sau.com.au/forums/topic/370094-v35-el-gauges/#findComment-5899963
You my friend, are amazing!
Yes ...yes he is. :blush:
:rofl2: .....But yeah it looks great, much better than the stock cluster.
Do you know where i can find one to suit the 04 S2 Sedan?
I must be blind i was trolling the G35 Fourms... It seems that half of the aftermarket items suggested there are not useable.
https://www.sau.com.au/forums/topic/370094-v35-el-gauges/#findComment-5904340
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
