Im not saying that $1500 isnt much for me personally, but some out there who spend the big $ on parts for rebuilds then a new crank is the least of their problems. Go look in the for sale section and theres a few threads with parts in there like $13K for a block or $11K for a head...add each part of that into a whole setup and the $1500 for a crank suddenly seems insignificant.
agreed. . .its not cheap going fast!
  • Replies 46
yeah like I said $1500 is not expensive when doing a build with top $ parts. look at the price of the other gear and then decide if using a used crank which is potentially bent is worth it? of all the used RB26 cranks i've seen more were bent than those that were straight. I know a number of people who've bought used cranks only to have them checked and find them unusable and then do it again a couple of times before getting a good one. it doesn't take many used cranks or machining bills to get to $1500.
anyway for the original poster who wants some advice I will give some of my own experience.
fit some aftermarket valve springs. even tomei type A (type B are much better and worth the extra $). that will allow you some headroom if you want to rev and personally I would NEVER fit aftermarket cams with stock springs.
secondly, don't use the tomei pump with your stock capacity sump. yes you have it baffled but the tomei pump flows so much more oil than standard if you run high RPM for any decent length of time you are going to pump it dry. even with the 1.2mm restrictor oil will be pumping up many times faster than it can return to the sump.
consider fitting a larger sump to cope.
the other stuff all sounds fine and good choice on the tomei rods, they are excellent. there's no problem running 500-600hp (engine) on N1 pistons and rings either as long as it's tuned well.
if you do want to run some decent power and boost though I'd consider using a tomei 1.2mm gasket (or other MLS gasket but you already have lots of tomei gear so I suggested that one). even buy the tomei gasket kit. it comes with a lot of the other gaskets you'll need.
good luck. :)
Hello Beer Baron and thankyou for that info.
From what i have gathered from doing research these past few days it looks like im going to go with a Nissan subassembly assembled and strip and recheck it as the cost of parts alone is coming up to more expensive before assembly by 500 usd or so.
So thats 500usd more for a set of tomei rods included in parts alone.
Im assuming that Nissan has a greater mark up on parts then on a complete whole sub assembly unit.
never the less i wont need to check much accept check that they have cleaned the block correctly that means stripping the motor.
Then checking the clearances correct on mains and big ends etc .
Reason i say this is because there has been a number of people who have bought complete engines from Nissan and checked the clearances etc and found problems, as well as with the R type rebuilt blocks that also have had loads of issues including the engine i bought from a company called Flatwell racing, they supplied me a engine rebuilt from nissan and it was a dud.
So be carefull out there .
I have a nismo head gasket already are these no good 1.2mm?
I have a extended sump that also holds about 7.8 litres of oil i dont know if this is enough or not ?
What is the average sump extension size ?
Hope to hear back from you thanks for the advise Cheers
Adam
Ps the cams i had were being used on standard valve springs .
they are 264 degree cams intake and exhaust .
Hello, just a small update was looking at my cams and went on the greddy trust website .
http://www.trust-power.com/overseas/ov_products.html?cate=6&item=152
This is a drop in cam shaft and happens to be the cam shafts that i have model 13526204
Seems that i dont need uprated valve springs .
So im lucky on this one :)
will keep you guys updated when i get the short block assembly have to save up for it tough one .
Thanks for that heads up had me thinking there quite a bit.
lol this ones for keeping close to stock.
The beast will come in the form of a gtr32 possibly as i dont see the point in modifying this clean car lol.
It will be a weekend cruiser and some times a day cruiser.
But i do want to make horse power and im seriously thinking of going for a rb30dett sounds exciting but that will come later.
thanks for the help will post again soon once i have the ever so big lump of cash for the short block assembly.
  • 6 months later...
Hello,
Just needed to ask, i have the crank and the grading on the top says BBBBBB and the bottom figures for grading are 0000000 can any one confirm why the top grading marks are no more numbers but letters ?
Is this a more recent update on the cranks and we dont have the new enough engine manual for it ?
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
