HI Everyone. I've been a well known genuine user on SAU for quite a few years.
Unfortunately some f**king tosser didn't give way, and me, going straight through a green light, plowed into them.
So, my much loved R33 is dead. Well, almost.
I'm parting it all out, and to make this easy, I will tell you what isnt available. Assume everything else is.
Parts NOT available:
1. Engine - Sold
2. Gearbox, Master and Slave cylinders, clutch Pedal - I'm keeping
3. Suspension - I'm keeping
4. Exhaust and intake pipes - I'm keeping
5. Shifter - I'm keeping
6. Windscreen - Smashed
7. Front Bar - Smashed
8. Right Fender - Smashed
9. Bonnet - Smashed
10. Right Headlight and other right lights - Smashed
11. Right control arm, and this bits - Bent
12. Not sure if selling the PowerFC and hand Controller yet
Parts Available:
All Interior - and that means absolutely everything. Just note the airbags went off - SO Steering wheel and passenger section damaged
Engine parts
Excedy Twin Plate Heavy duty clutch and lighter excedy flywheel kit (Still about 80% good)
Both doors
Sideskirts
Windows
Brakes
Left Fender
Boot Lid
Series II rear spoiler
Skyline Center Section lights up an aqua colour (pics attached)
Tail lights
Rear bumper
Diff
Axles
Rear wheels and tyres
Rear windscreen
Quarter Glass
Insides of the boot
Side Mirrors
Extra Green Passenger Mirror
Anything else that isn't damaged.
I will be updating this as much as I can and often so keep an eye on this thread.
You're welcome to PM me anything.
my number (written backwards to stop spam) 7046339340
my email paceys[at}gmail.com (change [at} to @)
Thanks guys
Jono
pics:
GOD DAMN, what a shame because of some one stupid action!!.... ill leave it there, or ill go on a 72 page rant!..
hey, were are you, qld?, would love some silver parts :) . sorry for the lose, loox like you had worked hard on this
Gutted for you man, that's terrible. Sorry for your loss.
Will keep in mind for parts I may need since I'm just starting a skyline journey and I'll pass on for others too.
All the best selling the parts...
Thanks for all of the kind words everyone.
The brand new RB25\30 motor and fully reconned gearbox had only done 1,500 kms when I had the accident...
Its a f**king let down, thats for sure.
I'm after ALL the rubber bungs and bump stops from the boot, and also the boot cover on the inside of the boot itself. (carpet liner?)
The bottom boot carpet too.
If the rubber bonnet stops are still on the radiator support, both of those too.
Price including shipping to 2087 pls.
Thanks!
-Steve
were you drunk when you posted that?
Ahh shit stick, my phone and its auto correct. I was asking what kind of rotors do you have there. I can't see what I'm typing until I submit the post.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
