hey guys, having a bit of trouble right now getting the brake line to unbolt from the caliper. its a 10mm nut but just seems to be strip over when i try undo it,
possibly shitty spanners i have but any suggestions? thanks. can provide pics if necessary
https://www.sau.com.au/forums/topic/370120-brake-line-nut-not-undoing/
Is it just spinning or have you rounded the hex head off?
rounded :( its alright, only rounded on one bit of the nut, so i undid it further up the line and then took it off and got around the other side.
worked a treat ahah, not keen about putting it back on, will probably source another.
lots of brands make flare nut spanners. I got some KC tools - they are sweet for cheap. Make sure they are derived from 6-point spanners not 12-point.
Edited by simpletool
For flare nut (and open ender) spanners its worth spending the dollars to get a good brand IMO. I have some KC flare nut spanners and while they're nicely made i sort of wish i'd gone kinchrome or equivalent. For ring spanners or sockets i'd imagine the KC stuff would be great.
www.vektools.com.au - i think i got my KCs from there too.
And you can get away with say two pipe or flare nut spanners [covering 4 sizes] and they will fit just about every size you will come across in the auto world. So not a big expense really. I have Dowidat ones, top shelf stuff, had em for a while.
probably a vice grips or a small plumbers wrench with the serrated teeth?
there is a tool that I've got that is similar to those and locks on to the nut end, strangely enough, I think its Dowidat as well. I'll have a look when I get home, but I reckon several tool makers would have something like it. Its a butchering tool for when all else fails.
The other tool that comes to mind is a stud remover, but you'd have to have the other end of the pipe undone so you could slip it over and down onto it because these tools are not open ended.
When one of my turbo lines was just stretching the KC flare nut spanner apart and rounding off the edges, i just cut off the pipe off so i could use a socket, and it came out easily. I figured it was already stuffed enough to warrant replacement, so no problems in cutting it off.
I have used hose spanners for brake work. You usually end up rounding the nuts anyway. The are better than open ended spanners buy not by much.
http://www.sidchrome.com.au/product/7473/5-piece-metric-flare-nut-spanner-set
Now I just use vice grips for undoing stuff. Irwin have a huge range of them. Find the right size with a straight end & you will be fine.
eg:
http://www.irwin.com/tools/locking-tools/fast-release-locking-pliers-sets
Edited by djr81
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
