hey i currently own a r32 rb20de, coming off my ps soon and i have purchased a rb25det neo with loom and computer, many may say search but i have searched everywhere and can not find anything on how to wire it up all help is much appreciated any pics, wiring diagrams or tips
big job done it a few times about 60 wire connections and new wires needed. r32 engine loom has wiper, abs, auto and altesa wires in it, not to mention cluster and consult signals. so if u use the 34 loom u loose all these connectons and need to be made depending on what ur car runs.
u can find all of the wiring diagrams for theses models online mostly ecu pinouts. its hard to find a good wiring diagram with connector location, wire pinouts and wire colours. most of the time u just have to use experience and a multimeter.
what ever u do double check all ur connections and dont leave the battery connected causing a little cook up, seen that a few times!!
Use an rb20det loom and sensors with a nistuned rb20det ecu. If you use an S1 rb25det intake then everything bolts up sweet.
All you need to change then is the coils, cas plug, swap ECU and S1 rb25det TPS. This is assuming rb20det and rb20de loom is the same.
Don't use the 34 loom, be a complete flamin mongrel if you do.
Edited by Rolls
