White 96' R33 GTST, immaculate condition in and out no dents or scratches!
96,500km's
Manual
Turbosmart dual stage boost controller (hi-lo)
APEXi S-AFC II air fuel controller
Full HKS Superdragger exhaust, 3.5" mandrel bent with high flow cat
Blitz BOV
Heavy Duty Brass Button Clutch
Hicas 4WS
HKS Type 0 turbo timer, displays volts etc.
Autometer Boost guage mounted on A pillar
Dual Stage shift light
Nismo Gear Knob
HKS Pod Filter
Short Shift Kit
Strut brace front and rear
Racing Pedals
Red VHT sprayed Calipers
Series II Bodykit
Koni height and damper adjustable suspension with King Spring low's
17" BSA Racing rims 235/45's all round, brand new Dunlop Leman's tyres on front
Full central locking and 3 point imobiliser alarm
Dual airbags
Hicas 4 wheel steer and ABS brakes
Receipts for many of the above mod's, Lots of money spent!
Can be included, competition stereo. Pioneer double facing head unit ($1400), 220W Pionner front splits with tweeters and 300W 6X9's in Rear. Speakers powered by a 480w pioneer amp. Two 12" SPL Competition square kicker subs in box in boot powered by a 1000W Crossfire amp and crossfire sub control switch mounted under stearing column. setup worth $5000 legitimately can provide model numbers of every component if you would like to check.
Extra's: Tommy Kaira Wing sprayed same colour as car, White faced colour changing EL dials and blue axs seat covers.
$24,900 ono contact via email nismo_s13silvia@hotmail.com or pm me.
im in noosa about 2 hours drive from gold coast....if your genuinely interested pm or email me and we can talk further.
Add me to MSN mate. I got a bruz in Dickie beach, mate. My bruz said its about half an hour or so to Noosa. He said he can check out da car man.
reckless_motorsports@hotmail.com
thanks for the interest JOSH......you have far to much spare time on your hands :D
anyway...car is still fs, so come on people
looking at 24,900 with sound system, its genuinley worth around 6000 installed. If your interested pm or email me and we can talk further. The plates will most likely sold with the car, until its sold im going to keep them.
Car is still available, I thought it was sold today however it fell through. Anyone interested feel free to pm or email me. Cheers Matt
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
