Been trying to get my tailshaft out for the last week in my 32. Have dropped the rear section from the diff but the short end connecting to the box will not move. Have been tuggin the nuts off it, tried a few gentle taps with a hammer, a few firm taps with a hammer and have had a ratchet strap to beyond tight tryin to pop it out. Seems like a f**kload of trouble for something that should just slide out? Im guessing the spline is bent but surely the ratched would of got it out?
Any help would be greatly appreciated. cheeeeers
https://www.sau.com.au/forums/topic/370137-tail-shaft-removal/
so you've unbolted it from the diff,and the rear section isn't touching the diff anymore its facing the floor the mount is removed and the input shaft is ceased to the gear box ?
so its rusted on or the splines are crunched on the input shaft, last resort if your sure only the input shaft is held in by the gearbox then put a tow rope on the tail shaft and on a car pull it out, slowly, TAKE CAR OFF THE STANDS, JACK SO ITS BACK ON ITS WHEELS if you attempt to do this
other then that tow truck and to the mechanic
Edited by Dan_J
Well yes they are 2 piece, but they are connected in the middle, he says he has unbolted it from the diff and is trying the get the shaft out of the box. Hasn't mentioned he has taken it apart, centre bearing is bolted to both sides of the tailshaft and is bolted up to the floor of the car. Maybe he has is trying to take it out as 1 unit and has forgotten to unbolt it from the floor
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
