S13 AND 180SX PARTS FOR SALE
Spare parts from Halfcut and left overs from my turbo engine conversion, various parts from later model 180sx SR20DET halfcut, and some parts from my 93' Silvia, contact 0414310713 to enquire
- PICTURES NOW AVAILABLE, PM OR POST REPLY ME UR EMAIL ADDRESS OR ALTERNATE AND I WILL SEND YOU A PICTURE OF THE PART YOU REQUEST -
- S13 180sx 94' Suspension Components: (still on halfcut):
Front left and right Tie rods -SOLD
Driver Side Control arm -SOLD
Passenger Side Cotrol Arm
SR20 Engine crossmember
Front Stablizer bar (stock Front Sway-Bar),
Front Driver and Passenger Stub axles and Dust Covers, No Disk and
Calipers.
- S13 180sx 94' Steering Components:
Steering rack and Column
Indicator and washer control assemblies (Stalks) and ignition chamber
with Nissan Key
Power steering reservoir and Lines
- S13 180sx 94' Air Conditioning and Cooling Components
"SR A/C Compressor (Zexel) may be compatible with other Nissan ie
CA, Pulsar, EXA - ask me for part # - SOLD
A/C Condenser - SOLD
A/C Gas Cooler and A/C Gas Cooler Fan (Zexel)
A/C Thermo fan - SOLD
Misc. external/internal A/C piping, internal dash a/c vents & ducting
Radiator and Fan shroud (stocko - Calsonic Brand) - SOLD
Analogue Climate Control unit (avail. soon)
- S13 180sx 94'/Silvia 93' Interior Components:
Silvia 93' Speedo intrument cluster (Silvia's seems to use yellow
bulbs as 180sx's seem to use a whiter globes)" - SOLD
S13 Centre console - SOLD
S13 Steering column interior shroud plastic bits (upper and lower, no
holes from boost guage mounts) - SOLD
S13 Plastic gauge cluster cover (contains the fog light buttons, rear
defog button, hazards, a/c vents etc. for 180sx) - SOLD
S13 Lower steering shaft cover (Plastic bit above driver' knees)
S13 Misc. interior plastic bits, except doors, all black trim, no A-pillar, all
in black trim.
S13 Silvia 93' dashboard (black trim, slight cracks above cluster vent)
S13 180sx 94' passenger glove compartment in updated wavy velour
trim with Nissan key - SOLD
S13 180sx Gearsock (Really chopped up by prev owner to fit short
shifter) Gear sock plastic mount -SOLD
S13 180sx Fusebox (Driver kick panel) and Cover
- S13 Misc. Electrical Components
S13 Silvia 93' SR20DE ECU (prefer to sell with engine)
S13 180SX Engine bay Fuses, electrical lines, Headlight and Foglights
Fuse box (not 100% sure, I hav a Sil and the 180 halfcut has 1 extra
fuse box for da lites)
S13 180sx 94' Windsreen washer Motor
S13 180sx 94' Halogen type Foglightes/driving lights (stock ones)
prepare for those winter fogs! $50ono (pair)
S13 Silvia passenger side Wedge lits and blinkers, no brackets and clip
(my old one, thanks Serial Killa)
- S13 94' 180/93' Silvia Engine Bay external parts:
S13 Silvia 93' SR20DE Brake master Cylinder (Still on my Sil)
S13 White 180sx 94' Front left and Right Fenders (Quarter Panels), no
splash guards (a bit dinged up due to transportation, overall ok)
S13 Silvia 93' Stock Springs - set of 4
S13 180sx 94' SR20DET Clutch Master Cylinder + Resevoir
S13 180sx charcoal canister, stock Fuel Filter, misc. rubber lines
S13 Silvia 93' non-turbo Air flow meter
S13 Silvia 93' SR20DE Air Induction pipe (not 100% where it goes)
S13 SR20DE Airbox and resonator (lower bit only available)
S13 180sx 94' clutch, brake, throttle pedals (clutch pedal, brake pedal
and clutch cylinder maybe sold together for manual conversions)
S13 180SX 94' Battery Tray (just incase if you've chopped ur 1 to fit a
FMIC and need another 1)
S13 180SX 94' Complete Lower Bonnet hinges
S13 180SX 94' Window washer, pump, reservoir and lines (Jets on
Bonnet not avail.)
S13 SR20 Exhaust Heat 02 sensor
S13 Silvia 93' stock Mudflaps (black)
S13 Silvia 93' Q's Steering wheel
S13 180sx 94' Radiator support ledge - just incase youve had a front
end with a commonhore
S13 Silvia 93' Boot (internal) side plastic covers (ones that cover rear
struts)
S13 180sx 94' Wipers and wiper water vent/drain - (the one that sits
outside, below thw wipers and windscreen)
-GAB S13 "Super R" Damper Adjustable front struts/shocks with springs, perfect stiffer upgrade from stock, no leaks - Has adjustable knob at the top of strut with '1-2-3-4' settings $280 firm
PM an offer or call regarding parts
-Meetups can be arranged
-parts bought as package, price is negotiable
-will consider interstate, depending on part
OR
If u wanna buy the whole Halfcut wrecking as is PM me an offer
More parts available ...............dat all i can remember....ask me if i have a certain part, i may have it, some parts here I cant name pictures at request.
________________________________________________________________
SR20DE FOR SALE
Selling due to my SR20DET conversion....
93 SR20DE 115'000 kms travelled no gear box (was 5spd manual) (bought car Nov 01 at 86K kms with slips to prove), serviced last at Unique Autosports May 2003 (receipts avail) with NGK iridium Sparks installed and Plenum chamber cleaned. Engine overall is excellent A1 condition, I had no problems with it (i just wanted a DET). Engine perfect use for replacements, projects, spare parts, spare engine or even to put in a lighter car, CA18 S13 or other car.
Complete Engine package = SOLD PENDING
Engine Specs:
Non Turbo, Twin Cam 1998cc, 4 Cylinder, 2 Litre, RWD available, 140 hp (105kw), 18.2kg.m (178nm) at 4800rpm
most import shops sell these between $700- $1100
prefer SYD buyers, will consider interstate call 0414310713 or post reply or pm me, im located west SYD
https://www.sau.com.au/forums/topic/37019-s13-parts-4-sale-must-go/
