Time to buy a new clutch for my build as i need to get it balanced with my crank. Aiming for mid to low 500's at the wheels.
Opting for the OS TS2CD, item was originally in the vehicle and felt like OEM item (only had 350hp though). Can only find 1 site with its rating and it says up to 600hp. Have also been recommended the excedy hyper multi (twin plate), or the excedy hyper compe-d.
Im after a clutch feel that wont make my car a bastard of a thing to drive. The OS giken clutch that was originally in the vehicle felt like the OEM item and is why im opting for it this time too.
Your opinions pleas?
https://www.sau.com.au/forums/topic/370209-os-giken-ts2cd/
Yeah they are good. Being a "c" means it has the larger diameter plates so its power rating will be higher than the b type os twins. Os make great clutches. I've personally owned probably 5 or 6 in various cars all twins or triples and whilst they can be noisy and sometimes a bit grabby they are super reliable and in my experience their power ratings are fairly conservative. So if you'll have 500hp(or did you mean kw?) at the wheels then a 600ps rated os giken should be fine. Personally though if it were my car with a genuine 500hp atw and it was going to be track driven I'd consider a triple as with more surface area they deal with the power and heat really well and hardly wear at all if driven properly. But if you already have the twin and it's in good shape just use that.
https://www.sau.com.au/forums/topic/370209-os-giken-ts2cd/#findComment-5905260
Cheers for that Mr Baron.
Ended up ordering a TS2CD the other night off RHD for a pretty cheap price. Had to order another one as this one was KECK. Needed to get balanced with the crank so i kinda needed ASAP. Car will probly not see many (if any) track days. Was really happy with the way it performed before my engine detonated, just wasnt too sure if it could handle my new aimed power figures.
https://www.sau.com.au/forums/topic/370209-os-giken-ts2cd/#findComment-5906303
i'm sure you'll be happy mate. they're a good thing. should have just bought the rebuild kit though providing flywheel and cover were ok? comes with new plates, new sandwhich plate and new top plate/pressure plate and bolts. you just retain the original diaphragm, carrier and flywheel. cost around $1000-$1500 depending on model.
https://www.sau.com.au/forums/topic/370209-os-giken-ts2cd/#findComment-5907644
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
