045HOW Posted July 9, 2011 Share Posted July 9, 2011 I'm not going to even bother. Try reading through this. For the record, R34's have 5 studs already. Woop de doo basil. where's your 1k to just whack a turbo on? Its not that easy. Its not that cheap. Its not that smart. and it is retarded. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905123 Share on other sites More sharing options...
045HOW Posted July 9, 2011 Share Posted July 9, 2011 1. Mods on N/A cars are not worth the money : kW outcome 2. Only real power = engine mods 3. Engine mods are illegal (points back to point 2) 4. Engine mods are expensive (points back to point 1) 5. Even if a turbo was bolted on, max power with awesome mods won't be greater than 300kW at the wheels 6. Value of the car stays the same, if not decreases because of the mods 7. If an RB25DET was dropped in, brakes, suspension, gear-box, clutch, ECU...etc...would all need to be upgraded which defeats the purpose of "cheap turbo" 8. I'm running out of single digit numbers This man on the other hand,is smart and not retarded. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905128 Share on other sites More sharing options...
Converge Posted July 9, 2011 Share Posted July 9, 2011 (edited) Woop de doo basil. where's your 1k to just whack a turbo on? Its not that easy. Its not that cheap. Its not that smart. and it is retarded. *facepalm* Try the SEARCH. This debate has been had many times, there are pros and cons either way. It's sad you had to resort to personal attacks over something like this LOL. Last time I view this thread. Edited July 9, 2011 by Converge Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905140 Share on other sites More sharing options...
045HOW Posted July 9, 2011 Share Posted July 9, 2011 Pearls of wisdom. Swine. I will say no more. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905148 Share on other sites More sharing options...
lincellusion Posted July 9, 2011 Author Share Posted July 9, 2011 I have spawned a monster through thy topic I hast started lol Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905179 Share on other sites More sharing options...
mad082 Posted July 9, 2011 Share Posted July 9, 2011 Although I have noticed that all, or most of the sz supras (the non turbo p plater friendly ones) that they are only 5 speed manual. What would the top speed be? and are there any real draw back, or any advantages to having a 5 spped manual over a 6 speed manual? cheers. not that much different to the 6 speed gearbox since 5th gear on a 5 speed box will be taller than 5th gear on a 6 speed box. without looking up the actual ratios i'd say that it is nearly as tall as 6th gear. either way, you would never get close to hitting redline in 5th gear as it won't make enough power to overcome the wind resistance at that speed, and there is a good chance that with the taller 6th gear the top speed would actually be lower. even a turbo supra with mild mods would struggle to max out both the 5 and 6 speed gearboxes since the gear ratios would put it at about 250 to 260kmh. *facepalm* Try the SEARCH. This debate has been had many times, there are pros and cons either way. It's sad you had to resort to personal attacks over something like this LOL. Last time I view this thread. unless you get all the parts second hand and dirt cheap and do a half arse job and only plan on running stock boost you won't convert a NA skyline to turbo for under $1000. this is a fact and if you have a good read through the thread you linked to you will see that i'm right Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905214 Share on other sites More sharing options...
lincellusion Posted July 9, 2011 Author Share Posted July 9, 2011 not that much different to the 6 speed gearbox since 5th gear on a 5 speed box will be taller than 5th gear on a 6 speed box. without looking up the actual ratios i'd say that it is nearly as tall as 6th gear. either way, you would never get close to hitting redline in 5th gear as it won't make enough power to overcome the wind resistance at that speed, and there is a good chance that with the taller 6th gear the top speed would actually be lower. even a turbo supra with mild mods would struggle to max out both the 5 and 6 speed gearboxes since the gear ratios would put it at about 250 to 260kmh. unless you get all the parts second hand and dirt cheap and do a half arse job and only plan on running stock boost you won't convert a NA skyline to turbo for under $1000. this is a fact and if you have a good read through the thread you linked to you will see that i'm right Gr8, thanks. so basically a 5 speed manual supra is the same as 6 speed, except the time spent in each gear will be slightly longer? (if that makes sense)? Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905280 Share on other sites More sharing options...
Miguelone Posted July 9, 2011 Share Posted July 9, 2011 Please show me this 1k mastery you speak of. You would have to upgrade the braking system to GTST brakes,and i dont believe that just means calipers. You would want to upgrade your hubs to 5 stud instead of 4 stud. then you would need a turbo diff and possibly a different stronger tailshaft.then comes a gearbox,you would be needing a turbo gearbox to handle the power because n/a gearboxes are not the same box and are weak.and after all this,you can't just bolt a turbo onto an n/a.you need new fuel pump,injectors,manifold,turbo,gaskets,ecu,intercooler,piping,new holes to be cut in the body for intercooler piping,bov,lower the compression and there ain't no guarantee of how long the setup would last.and after getting it all done and f**kin around,you have to get it engineered and modplated which can be a massive f**k around. Or you sell an n/a for way more than its worth because of these laws to a kid that would like to drive a skylines on their P's and you buy a GTST/GTS25T/GT-T for less or as Much money as you sold the NA for and lo and behold it already has all the turbo gear already in it with nothing missing,no engine to take apart and no certificates and modplates to procure. Hope this helps to the enth degree. You buy a stocker turbo and chuck all the gear you've aqcuired onto it. Then sell the now stocker NA to another kid coming onto P's and the cycle repeats. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905285 Share on other sites More sharing options...
w34ponGT Posted July 9, 2011 Share Posted July 9, 2011 at the end of the day this kid doesnt know what he wants and will end up with whatever his parents give him Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905544 Share on other sites More sharing options...
lincellusion Posted July 9, 2011 Author Share Posted July 9, 2011 at the end of the day this kid doesnt know what he wants and will end up with whatever his parents give him I already got what my parents gave me, the saab, I am trying to decide what to buy with the money ive been saving... Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905561 Share on other sites More sharing options...
045HOW Posted July 9, 2011 Share Posted July 9, 2011 You buy a stocker turbo and chuck all the gear you've aqcuired onto it. Then sell the now stocker NA to another kid coming onto P's and the cycle repeats. That's how its meant to go down. Is your car a genuine gts25 33? What year was it imported. you are pretty lucky to have that car,they are no longer allowed to be imported afaik. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905564 Share on other sites More sharing options...
Alkatraz Posted July 10, 2011 Share Posted July 10, 2011 I dont know anything about what you can or cant drive on your P's and I am pretty new to the skyline scene, long time car enthusiest though, but have you considered a v35 skyline? http://carsales.mobi/cars/details/?R=10835883&Cr=7&trecs=13 (sorry, thats from my phone) I know that it is on a completely different tangent to a 33 or 34 and definitely not as tough but trust me, you will get more loving from the ladies in one, especially at your age. I think the na v35 would be quicker than the 33 or 34, not to mention the better interior etc. Anyone is welcome to rip apart any of this because I really have extremely little Skyline knowledge. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905945 Share on other sites More sharing options...
Goombeh Posted July 10, 2011 Share Posted July 10, 2011 Yeah that's one thing I don't like about the rest of the Silvia community Why would you put 215's over 9.5 inch wide rims? Seriously Just so we all keep our minds open, I used to setup and fabricate components for the Australian Sport Sedan series and we would do a lot of setup for guys who did club sprints and the odd trackday also. And we nearly always ran a stretched tyre on the track setups, as this assisted in the reduction of the time the tyre would "set" into load at initial turn in and improved steering response as a result, but it would still allowed the tyre to retain the radial compliance from an unchanged sidewall profile so as to not alter the straight line and corner stability through bumps. Just some insight. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905979 Share on other sites More sharing options...
stig mick Posted July 10, 2011 Share Posted July 10, 2011 Any street car running like that is only doing it for street cred though Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5905988 Share on other sites More sharing options...
lincellusion Posted July 10, 2011 Author Share Posted July 10, 2011 I dont know anything about what you can or cant drive on your P's and I am pretty new to the skyline scene, long time car enthusiest though, but have you considered a v35 skyline? http://carsales.mobi...3&Cr=7&trecs=13 (sorry, thats from my phone) I know that it is on a completely different tangent to a 33 or 34 and definitely not as tough but trust me, you will get more loving from the ladies in one, especially at your age. I think the na v35 would be quicker than the 33 or 34, not to mention the better interior etc. Anyone is welcome to rip apart any of this because I really have extremely little Skyline knowledge. Funny you should mention this car. me and a mate went car searching (I was helping him find a car since he crashed his civic) and he ended up getting a 300gt (p platers cant drive 350gt). he got it with aftermarket rims for $15800, and it had only done something like 29000 km's. it has 191kw and it very nice inside and out. but in all honesy, I just do not like its size and its 'luxurious' interior. believe it or not, I hate luxury cars, I love the interior of a race/ sports car lol. were picking up the 300gt on wednesdya, so I will be able to give it a good drive then (hes letting me drive it), but ye, I appreciate the thought and recomendation, but I am not really into those cars. I know its a very safe car and all, just not my style. AND I know what you mean about it picking up ladies, thats why he wanted it But I dont really care what appeal the next car I get is to the woman haha, I mean hey, girls dont mind my saab that im driving right now anyway Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906048 Share on other sites More sharing options...
Miguelone Posted July 10, 2011 Share Posted July 10, 2011 That's how its meant to go down. Is your car a genuine gts25 33? What year was it imported. you are pretty lucky to have that car,they are no longer allowed to be imported afaik. The GTS, RB20E models can't be imported any more. The GTS25 RB25DE models can though. Mine came in in 2001 Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906057 Share on other sites More sharing options...
lincellusion Posted July 10, 2011 Author Share Posted July 10, 2011 how come the rb20's cant be imported no more? Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906093 Share on other sites More sharing options...
Miguelone Posted July 10, 2011 Share Posted July 10, 2011 Power to weight ratio is too low, same reason we can't get Kei cars. Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906101 Share on other sites More sharing options...
lincellusion Posted July 10, 2011 Author Share Posted July 10, 2011 ohhhhhhh Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906207 Share on other sites More sharing options...
stig mick Posted July 10, 2011 Share Posted July 10, 2011 Power to weight ratio is too low, same reason we can't get Kei cars. Really? Link to comment https://www.sau.com.au/forums/topic/370213-r33-or-r34/page/5/#findComment-5906246 Share on other sites More sharing options...
