http://www.carsales....20904&silo=1011
Pictures and details are in the relavent link above
This imported "2003 Nissan Skyline 350GT Coupe" (aka. Infiniti G35 Coupe) comes in a RARE Mediterranean Blue that doe not show its age and kept in pristine condition that will not dissapoint!!
With LOW KM (59700km) and is kept almost completely STOCK (apart from a few upgrades) for the next owner to do as HE or SHE desires.
Features of this car includes:
- A Powerful 3.5L V6 Engine delivering 206KW
- 2 more seats in the rear with sizeable leg room
- 17" Alloy Factory Rims
- Tiptronic Semi-Automatic Shifter
- Micro-Suede Interior Design with Metal Scuff plates and original Factory fitted floor mats
- Full Electics ( Automatic Fully Adjustable Supportive Seats, Windows, Auto Headlights and fold-in side mirrors)
- Climate Control with active Thermometer of the Outside Environment
- 6 Airbags including Side Curtain and Passenger
- Vehicle Dynamic Control (Switch allows it to be turned on or off)
- Drop-down angled side mirrors to allow for very easy parallel and rear parking (can be turned on or off with the push of a button)
- Comfortable Suspension and well balanced (53:47) for especially for long drives and good in the corners
- A Great Factory Sound System with punchy bass
- Fuel efficient and fuelled with 98RON BP ultimate
- Rear Privacy glass
- LOTS of Cup holders and compartments
Extras on this Car include:
- RDA Slotted Rotors Front & Rear
- Performance Brake pads
- New Tyres
- Boch Aerotwin Wiper Blades
- New Air Filter
- Clear Side Indicators
- Full service History
The car will be much missed and sad to see it go. PM/Call/SMS 0404 228 585 for further details. Genuine enquiries only. Thanks
Pictures and details are in the link below
Edited by Will Power
  • 3 weeks later...
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
