Stealth means asking on an internet forum..................hahahha.
Try mounting your switch under the dash somewhere? But one thing you don't want to do is have a switch that you have to bend to use - you need to be in your normal driver position and still be able to access it otherwise you'll look like your using a kill switch
I have a kill switch off the ecu area and I also have a battery isolator switch on a remote. My alarm - you could say - is direct feed to the battery so it is unaffected.
https://www.sau.com.au/forums/topic/370228-killswitches/#findComment-5901327
i wouldnt discuss a kill switch on here, they can be so stealth you cant see them or touch them. RFID chips . Iphone bluetooth, IP the list is huge, it depends on your budget and know how.
not many places in OZ know how to do a RFID or proximity kill switch. that I have found. anyhow
kill switches can as easy as a cig lighter or something you never touch just your "presense" is all you need.
https://www.sau.com.au/forums/topic/370228-killswitches/#findComment-5901602
thats the first place a crim will look, and a huge fail !!! and you just announced how to defeat your alarm to the world
https://www.sau.com.au/forums/topic/370228-killswitches/#findComment-5901607
a crow bar fixes that, and most of the time theyll break into the boot looking for easy to take items if they can't start the car
then your car gets ransacked , best bet is to stop them BEFORE THEY BREAK IN using common sense
then a mutiple layer protection
and ultimate a GPS interface that can remote shut off the car next time the brakes are applied below a set speed, or geofence
https://www.sau.com.au/forums/topic/370228-killswitches/#findComment-5904682
hate to say it but the last few 33s I have repaired from theft the boot was popped the pump relay bypassed and then the column smashed.
insurance is the best idea. some of the cars I do have remote relays on them and if they do not see a remote control signal they DO NOT work. google that. plenty of companies make them.
https://www.sau.com.au/forums/topic/370228-killswitches/#findComment-5906555
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
