Hey Guys,
I have a Nismo Gmax push type twin plate clutch for sale.
It has been fully rebuilt by NPC to handle 500rwkw.
All new fingers, springs and plates where fitted all surfaces machined.
The plates are now 6 puck solid centered items.
Suits RB20, 25, 26.
I ran it in for 1000+kms then raced at winton and blew my engine, now my car is going in a different direction
so i dont need this clutch anymore.
This is an awesome clutch, not too heavy but bites hard, real hard.
$1250
Located in Melb ( easterns )
Cheers
Campbell
0421840982
https://www.sau.com.au/forums/topic/370258-nismo-gmax-twin-plate-vic/
I've never driven a super copper mix but i drove this one to
work and back ect for a month and its was fine, even in traffic.
Because its still the same concept as a nismo just beefed up
it still drives nice.
Hope this helps
Cheers
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
