guys,
I am new to R34 GTR !! now I got one there is gonna be plenty of Q to come !! thank you for anyone that helps !!
I car comes with a bit of gears in already and jsut wondering the Stocj BOV what Boost level can it handle up to !! I dont really like having an aftermarket BOV !! I am chasing somewhere around 320QWKW on GT-SS !!
cheers
wen
https://www.sau.com.au/forums/topic/370259-what-psi-can-stock-r34-gtr-bov/
yeah i forgot about -9s, GTRSean ( the white 34 a texi) has these and they seem to be a good thing
:D -5/2530's aren't great for a street car stock bottom RB26, been there done that.
-9's will get you 300-330 wkws.
I have got nismo AFM's ready to go on once I get injectors, then I'll see what it gets!
Have a look in the RB26 dyno topic in forced induction for just about every setup you could think of.
And yep, the stock recirculation valves are a good bit of kit up to at lease 30PSI if in good nick.
i've had 1.4bar on mine with -7s, 320 on SSs maybe but i think you would be better off with 2530s
thanks for the advice, dont think I will been changing the turbo anytime soon ! as I just got the car witth GT-SS also the car is only a street car coming from an EVO background I think the GT-SS is already laggy !!!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
