are these the ones organiased through Del?
I had a long chat on the phone to him about it. Long storey short the company in the uk went bust, a new company bought it, and the windscreens are on there way to australia now.
http://www.ipraforum.com.au/viewtopic.php?f=8&t=6481&start=40
Hey ....
Hi.
Any news on when they will arrive.
They are already here see other thread ! :thumbsup:
Only a few available .... Current cost for remaining ones is now $535 + GST
Sorry .... I had huge problems with suppliers going bust on me. Basically had to sell most things off my race Evo to continue :( and keep my word .... This has warranted a business and now GST is mandated.
Contacts :
[email protected]
Tel : 61 2 4701 6498
Mob : 0422 425 026
Just for you Pete :thumbsup:
Cheers .... Del
Edited by Delboy
im sorry but what do these heated windscrens do?
the only thing i can think of is to remove the heating demister system, yet still have a window that can defog itself?
sorry for being a noob, thanks in advance
Hey ....
You have it in one ....
Removing all associated parts that operate the heating / demister system can relieve a race car of some 22 + kg, depending on fluid etc, even the plastic air ducting can come out !
A serious racer would kill to loose a further 20 + kgs when cars reached it limits with weight saving.
Apart from that it also pretty re-assuring at speed to see where ones going ....
Ultimately you will never encounter a fogged up screen again .... :thumbsup:
In the Old Bucket I own I lost 24 kg .... Wish getting simular weight off my ever increasing side profile was that easy :laugh:
CheeRS .... Del
  • 3 weeks later...
Well, Big del just delivered my two screens in person to Brisbane from Sydney. Looks like the little S-Cargo may have a dodgy big end though!
The screens look the business.
any pics of the screens?
I'm seriously considering getting one, esp seeing at my heater is already out :/
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
