I just ordered myself an ecutalk for my R33 GTR.
Having just realised the size of the unit, question one where have others put
their ecutalk. (Orginally I was going to put this in my ashtray / modify my ashtray etc)
But I don't think it will fit.
Question two are these things legal.
ta Henry...
https://www.sau.com.au/forums/topic/370270-ecutalk-questions/
no ecu change or piggyback is legal, be it a remap, stand alone, piggyback or modification of the stock one
you would usually get pinged for it as it alters the cars emissions
But on the ecutalk you can now change fuel / ignition timings , doesn't that count towards changing
car emissions.
Paul,
I think you are refering to the cars ecu, The ecutalk is just a diplay of the OBD, I beleive it can do changes only while the ignition is on and returns when off...
Montie.
they are ever so slightly smaller than a din socket. I have mine installed below my radio but above the ashtray...
pretty cool at dispaying stats etc , just have to figure out what they all mean.. doh! oh & update the firmware as well, havnt tried that one yet...
Ps much bigger than ash tray
Dazza
Edited by itshimdazza
Henry,
Sorry for the late reply but sent you a pm...
After looking at your I notived that you have the otherr din socket full of the 3 GTR gauges so i guess your stucj with were it is at present.
Here mine but in a GTST
The unit has already paid for itself.
I got an air flow meter fault. (i have had trouble in the past) and there is the problem.
Pulled my meters out & pods too.(totally filthy & lots of oil in the meters & pipes)
I've cleaned out the meters , and currently waiting for my new pods to arrive before
I put every back in.
Montie ur shifter and shifter boot where u get it from ? i got a series 3 but the boots i seen on ebay and auto shops looks shit as urs looks genuine lol
It come with the car. (so I can't help you if your looking for one)
My skyline is a series 2.(its got the red stiching on it)
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
