Hey all the clutch on my R32 GTS-T just died out on the way home :( the clutch itself is probably 9 months old and has never been driven hard. It basically lost all pressure in the pedal and wasn't springing back from the floor, the weirdest thing is that i had a brand new Master cylinder and a second hand working Slave installed only a month ago and properly bled up all professionally!! It seems to have dropped a small amount of fluid but the reservoir was still above empty, we attempted filling it up and bleeding on the side of the road for about 15 mins to no avail.
Does anyone seem to know what this may be or at least a general idea on what i should look at fixing? I'm going to have a decent look tomorrow to check for leaking or split lines but I doubt i'm going to be able to tell where the problem lies.
Cheers any help would be great
https://www.sau.com.au/forums/topic/370306-help-clutch-gone/
Yeah thinking the slave cylinder too, but nick shaw seems to think that one shouldn't have died, would the fork pivot ball cause the pedal to stick like that too? it has about 4mm of pressure when we were trying to bleed it up but not enough to get into gears or anything!! Cheers for the help man
Its good that you've figured it out mate, are you sure the slave cylinder is broken? as the slave cylinder failing wont cause the pivot ball to break, did the clutch pedal go really stiff when it broke or did the pedal just drop to the floor under normal conditions ? The hub that the release bearing is on may have gotten dry and sticky or could have even jammed causing more load on the pivot ball/clutch fork, let me know if you need any bits mate as i have a few gearboxes laying around.
i would say the pivot ball broke first causing the slave to hyper extend , the usual cause is from not being cleaned/re greased on clutch changes (if the clutch feels un-usually heavy , normally it's caused by this also) . the slave may be fine if you push the piston back in the chamber , there isn't much that can go wrong with them pinch.gif
Pretty simple little units, generally they just seize or wear/tear the seals.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
