  • 4 months later...
  • 1 year later...
Nice!
WV2 definitely same as the the s15 pewter colour, they didn't release them in KV2... trust me I spent almost a year obsessing over paint codes ;)
Agree though, not sure why they call it Pewter - looks nothing like my Pewter mug!
  • 1 year later...
well that is kinda freaky, haven't been on the forums for a while, check the vic section and my car thread is on the front page.
as for selling it? The dream plan is to keep her forever, however that's probably what a lot of us think.
Definitely no plans for imminent sale, sorry bout that. As for price? would not have the faintest... haven't been keeping an eye on things like that for a while. Are you interested in buying it or more curious to guage a price for what a car "like" this would go for?
If you are the type of guy like me I would definitely keep it and never sell it. I would be very much interested in buying it if you decide to sell it in the future!
I know a Vspec2 Nur is $70000-$75000 at auctions. There is one similar like yours in japan, with price around $72000-$74000 , depending on exchange rate of japan dollar. This is from a dealer though, plus importing, complance, shipping costs if bought to aus.
The reason why I am interested, I am looking for a car exactly like your and in no hurrys and this car mentioned above is similar colour etc.
Plus what you have done to your car in mind is complete and what Iam looking for in a car with the added mods also.
If you mind me asking how much did you pay for it, please PM the price
What sliver colour code is your car?
cheers!
  • 1 month later...
Hey man, sorry if I missed it in the thread but what Bride's did you end up getting? Are you using Bride rails? And if you are, are they hard to slide the seats and adjust the seat position?
Awesome car by the way!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
