legnum lol.
now dont be like that. stock for stock the Legnum VR4 has a lot more punch than the Stagea.
its ok to be Nissan loyal, but the Legnum VR4 is still a damn fast wagon. And if it wasnt for the mega expensive servicing and parts... id definitely be looking to slide into one. Although compared to a M35, the old VR4 is starting to look a bit dated.
Edited by SU8TLE
  • Replies 42
ARX lol.
oh wait
yeh i know that but i think just for the price comparison of the two, you definitely get more out of a m35. i drove a legnum and wasnt impressed to be honest
yeah true. the one I had a spin of had the boost up'ed a few psi and larger FMIC, and on boost it drinks like a whale. but i think the AYC in the Legnum around some twisty's is where the Legnum really shines. EVO handling ftw.
But as a family car... the M35 Stagea is a better option. Thus, my interest. Im just also a big fan of the Legnum VR4, spent a bit of time over at OzVr4.
you'd be suprised at how the M35 handles with some coilovers and a set of sway bars.
honestly even i was suprised with just the BC's i installed.
btw, what settings did u use for ur BCs aaron? how many clicks front and rear?
Edited by Sydsyd
When I was looking for a replacement for my Mazda 3 I was looking at the Legnums too...the AYC was a big plus.
But the lack parts and servicing cost was too much to bear...
LOL...hater!
I guess alot of people said the same thing about airbags/abs/awd/tcs etc etc when these things were 1st put into cars...:whistling:
lol if your going off that the trend looks like it wouldve started as.
"a car is for a person that cant drive"
i dunno if the heights properly set. i could lift the fron1cm more or so.
fronts are 12 from hard and rears are 15. feels ok, the rears arent loosing so much traction now
Oh man, don't get Iain started on ABS.
You'd might as well start talking oil/fluids with me!
hence why i said fair enough lol
not that big of a difference. its only damper after all. plus its only bee just installed so the novelty affect is still there.
    • A bit of data is always good, beats the Facebook experts with their opinions I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
    • Correct And whatever you do, don't use an oil pump gear, especially the one that starts with the same letter as Santa and the last letter ends with the same first letter as Lagoon. Get a proper oil pump, like a Nitto, Tomei, etc. and make sure you invest in a big fk off sump. Won't go into too much detail, but I am sure it caused my previous built motor to go bang.
