if everything else is still standard (bottom end, head bolts etc) then i'd just stick with a nissan gasket. 30e gasket is around $95 from nissan
That's what my OEM RB26 gasket cost from Nissan (trade). Genuine exh. manifold gasket cost more than the headgasket!
Genuine exh mani gasket cost like $120 trade :(
I've found Nissan really good in some aspects but then others like seals (forget it) and idlers/tensioners I source elsewhere (get my idler/tensioner bearings from Statewide Bearings for dirt cheap!).
the only thing with the nissan head gasket is i cant order the thickness i want...
beacause if they have to shave the head a fair bit to get it back to flat i will need a thicker gasket for the right compression wont i?
Not always. What they take off is usually only 5-10 thou. Most of the time it would be less. But thats only a maximum of 0.250mm. So long as you have adequate piston to valve clearance, the extra compression wont be alot or bad. If anything it will make it abit more responsive off boost and help reduce lag by some immeasurable amount.
Unless you are building a low comp big boost high hp motor, then it would be a different story.
I will attempt to find out. I didn't do the decking, I bought the setup like that when I built my first 30. I got the block/head/pistons from a matching setup and chucked in a stock crank and rods. I'm now using the same head on a stock n/a bottom end.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
