before pulling the starter motor out:
Check your battery voltage, both just sitting with everything off (Should be about 12.6V or so) and then during cranking (shouldnt drop below 9v from memory, even 9v I think is getting to low)
if this checks out, put the car in gear and roll it back or forward a bit (the gear for the starter might be jammed against the ring gear.
But if this fails then I'd say it would be the starter motor as suggested
sounds like mine when my battery dead, the battery got not enough power to start the car. If jump is working then your car can still use the battery for a few days/weeks?
Jump means you taking other's car battery power to start your car and then you still use your underpower battery, the car do charge the battery but it won't last long anymore. It will die soon so replace the battery asap.
Not true, my battery has gone flat about 3 times in the last year and is still fine.
Only a cheap compliance battery as well....
yeah same..get a proper (plug in the wall) battery charger, bunnings has them cheaper than auto stores, I got a fairly decent one with an engine start option on it as well for about 60-80$..
my battery has gone flat numerous times..but after a good overnight charge its good as new..
If battery keeps dying, won't it be an alternator problem?..
Or is it because of the cold weather? I know that short drives + loud music w/ sub can drain the battery before the alternator can charge it
Ohhhhhhhhhhhhhh, maybe that's what happened to me!!! i had pretty good sound system and maybe the battery went flat before the alternator charge it!! That is why the battery keep going flat and die. And short drive yes :(
That makes perfect sense, I recently moved within 15mins of my work and only drive the car there & back at night.. with the sub going nuts lol..
You need to check that you don't have a drain somewhere in my car. My old car had a dodgy earth and the glovebox light was shorting to ground (not through the switch) and staying on
This over night was draining the battery
Simple check I guess you could do to eliminate a failing battery is unplug it (negative first) and leave the car sit over night and plug the battery back in. If all is well then it's a problem with the wiring. If not it could be your alternator or your battery
RAA guy who came out to jump my car last night noticed my boot light wasn't turning off when closing the boot. We couldnt find the switch so thought it must have been in the lock.
Anyway, pulled the globe out yesterday and guess what? Car started first go tonight ^_^
Edited by awsam
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
